查看: 371|回复: 1
【转帖】PLAXIS Manuel - Finite Element Package
发表于 2003-12-8 10:04:51 | 显示全部楼层 |阅读模式 来自 Invalid
〖原创〗PLAXIS Manuel - Finite Element Package
xanadou
   发帖: 93
  于 2003-12-07 22:26
  Plaxis v8.0
PLAXIS is a finite element package specifically intended for the analysis of deformation and stability in geotechnical engineering projects. Geotechnical applications require advanced constitutive models for the simulation of the non-linear and time-dependent behaviour of soils. In addition, since soil is a multi-phase material, special procedures are required to deal with hydrostatic and non-hydrostatic pore pressures in the soil. Although the modelling of the soil itself is an important issue, many geotechnical engineering projects involve the modelling of structures and the interaction between the structures and the soil. PLAXIS is equipped with special features to deal with the numerous aspects of complex geotechnical structures.
Online Manuals
Below you can find the online manuals for PLAXIS software. The manuals are in PDF format. If you have Acrobat reader installed the link will open in your browser window. If not you can use right-click "Save target as.." To download the file to your computer.
Three PLAXIS products are supported by online manuals: the PLAXIS Professional versions 7 and 8, and the PAXIS 3D Tunnel version. The reference manual of PLAXIS Professional version 8 is also available in French, German and Italian.
Choose your manual below:
Plaxis professional version 8
Plaxis professional version 8, reference manuals (English, French, German, Italian)
Plaxis 3D Tunnel version
PlaxFlow
You will need the Acrobat reader software to read the manuals. If needed you can obtain a free copy by clicking the link below.
http://www.plaxis.nl/ie.html
@xanadou
不知道价格几何了?
发表于 2003-12-8 12:25:47 | 显示全部楼层 来自 日本
回复: 【转帖】PLAXIS Manuel - Finite Element Package
老早都出来了,这个:?:不用也罢!
GMT+8, 2024-10-1 03:25 , Processed in 0.026777 second(s), 10 queries , Gzip On, MemCache On.
