查看: 250|回复: 10
【讨论】求教大侠们安装中出现的问题
发表于 2004-2-2 16:15:12 | 显示全部楼层 |阅读模式 来自 武汉大学
《98 out of 99 licenses remain available》
FXGContextEx::create():uglcreatecontext() failed
abaqus error:abaqus/cae kernel exited with an error
是哪里出了问题?3x
发表于 2004-2-2 17:05:39 | 显示全部楼层 来自 日本
回复: 【讨论】求教大侠们安装中出现的问题
pls upload your verification msg by the following command:
abaqus verify -all
and then post this verify file here.;)
 楼主| 发表于 2004-2-2 19:04:05 | 显示全部楼层 来自 武汉大学
C:\Temp>abaqus verify -all
ABAQUS Product Install Verification...
Thu Jan 22 19:01:54 2004
Running system requirement checks.
Requirement:    Windows 2000 or Windows XP
Product:        All ABAQUS Products
Status:         Pass - Found Microsoft Windows XP Professional  (Build
                2600).
Requirement:    Checking system settings to improve performance
Product:        ABAQUS/Explicit
Status:         Warning - You may be able to improve the performance of
                ABAQUS/Explicit on this system.  For details, see:
                http://www.abaqus.com/support/v64/explicit_lock_odb.html
Requirement:    Default web browser should be Internet Explorer 5.5 or
                Netscape 6.0 or greater
Product:        ABAQUS/Online Documentation
Status:         Pass - Found Internet Explorer 6.0.2600.0
Requirement:    Fortran compiler command
Product:        ABAQUS/User Subroutines and ABAQUS/Make with Fortran
Status:         Pass - Found Fortran compiler command.
Requirement:    C++ compiler command
Product:        ABAQUS/Make
Status:         Pass - Found C++ compiler command.
WARNING: Verification for all selected products will be attempted, but some
         products may fail because of the indicated system deficiencies.
Making C:\Temp\verify. All verification files will reside in this directory.
ABAQUS/Standard
         ...PASS
         Continuing...
ABAQUS/Standard with User Subroutines
         ...ERROR
            ABAQUS did not complete successfully.
           &nbsplease see std_user.log for details.
         Continuing...
ABAQUS/Explicit (single precision)
         ...PASS
         Continuing...
ABAQUS/Explicit (double precision)
         ...PASS
         Continuing...
ABAQUS/Explicit with User Subroutines (single precision)
         ...ERROR
            Please see xpl_user_sp.log for details.
         Continuing...
ABAQUS/Explicit with User Subroutines (double precision)
         ...ERROR
            Please see xpl_user_dp.log for details.
         Continuing...
ABAQUS/Viewer
         ...ERROR
            Please see Viewer.log for details.
            Turning off hardware acceleration may correct the
            problem. See ABAQUS Online Support System Answer
            1249 for details.
         Continuing...
ABAQUS/CAE
         ...ERROR
            Please see CAE.log for details.
            1249 for details.
         Continuing...
Elysium direct translator for CATIA V4
         ...WARNING
            ABAQUS/CAE verification failed. Verification
            procedure will be skipped.
         Continuing...
Elysium translator plug-in for CATIA V5
         ...WARNING
         Continuing...
Elysium translator plug-in for I-DEAS
         ...WARNING
         Continuing...
Elysium direct translator for Parasolid
         ...WARNING
         Continuing...
Elysium translator plug-in for Pro/ENGINEER
         ...WARNING
         Continuing...
ABAQUS Interface for MSC.ADAMS
         ...PASS
         Continuing...
ABAQUS/Standard Parametric Study
         ...PASS
         Continuing...
ABAQUS/Explicit Parametric Study
         ...PASS
         Continuing...
ABAQUS/Design
         ...PASS
         Continuing...
ABAQUS Interface for MOLDFLOW
         ...PASS
         Continuing...
         ...ERROR
            Please see fortran_make.log for details.
         Continuing...
ABAQUS/Make with C++
         ...ERROR
            Please see cpp_make.log for details.
         Continuing...
ABAQUS/Make with Object Code
         ...WARNING
            ABAQUS/Make with C++ failed. Verification procedure
            will be skipped.
         Continuing...
ABAQUS/Scripting Interface
         ...PASS
         Continuing...
ABAQUS/Explicit with MPI-based Parallelization
         ...INFORMATION
            Product is not available on this platform.
         Continuing...
Clean-up...
Job files exist. Verification directory C:\Temp\verify will not be deleted.
 楼主| 发表于 2004-2-2 19:07:05 | 显示全部楼层 来自 武汉大学
什么问题啊?
安装倒是很顺利的!
发表于 2004-2-2 21:01:26 | 显示全部楼层 来自 湖北武汉
如果是Nvidia的显卡,看看驱动:NVIDIA 显卡高于40.00的驱动版本不兼容,同时还可能和其他的显卡不兼容,请参阅官方网站的相关说明,可以改用40.00以下版本的驱动,或者关掉硬件加速,当然这样会降低运行效率。
如果问题还未解决,请给出CAE.log的详细信息。
 楼主| 发表于 2004-2-2 21:14:35 | 显示全部楼层 来自 武汉大学
cae。log
ABAQUS License Manager checked out the following license(s):
"cae" version 6.4 from zwj
<98 out of 99 licenses remain available>.
FXGLContextEx::create(): wglCreateContext() failed.
ABAQUS Error: ABAQUS/CAE Kernel exited with an error.
 楼主| 发表于 2004-2-2 21:49:41 | 显示全部楼层 来自 武汉大学
谢谢wjytj 大侠,我已经把驱动版本改为了31.40,可还有硬件加速问题的提示,为什么啊?
下面是std-user.log xpl-user-dp.log fortran_make.log
df.exe文件是什么文件啊?
ABAQUS JOB std_user
ABAQUS version 6.4-1
Begin Compiling ABAQUS/Standard User Subroutines
1/20/2004 2:57:14 PM
ABAQUS Error: Problem during compilation - df.exe not found in PATH.
ABAQUS/Analysis exited with errors
ABAQUS JOB xpl_user_dp
Begin Compiling Double Precision ABAQUS/Explicit User Subroutines
1/20/2004 2:57:44 PM
ABAQUS JOB fortran_make
Begin Compiling User Post-Processing Program
1/22/2004 9:40:30 PM
Compiling: C:\Temp\verify\fortran_make.for
Traceback (most recent call last):
  File "ython/driver/make.py", line 887, in ?
  File "Python/driver/application.py", line 119, in run
  File "Python/driver/make.py", line 104, in execute
  File "Python/driver/make.py", line 447, in compile
  File "Python/HKS/uti/impl/uti.py", line 34, in spawnAndWait
ValueError: df.exe not found in PATH.
"viewer" version 6.4 from zwj
ABAQUS Error: ABAQUS/Viewer exited with an error
谢谢大侠们!!!!!!!!!
发表于 2004-2-2 22:47:50 | 显示全部楼层 来自 湖北武汉
那试着关闭显卡的硬件加速试试看,方法为:
编辑abaqus_dir\6.4-PR11\site\graphicsConfig.env, 修改倒数第4行:
hardwareAcceleration = hardwareAcceleration <---change this to OFF
std-user.log xpl-user-dp.log fortran_make.log出现的信息表明你未安装VC和VF或者其环境变量设置存在问题,请查看以往帖子。
 楼主| 发表于 2004-2-2 23:31:30 | 显示全部楼层 来自 武汉大学
6.4不需要再安装fortran和vc了吧?
发表于 2004-2-2 23:46:27 | 显示全部楼层 来自 湖北武汉
所有的本版都是用得着就装,用不着就可以不装。
bahjian 该用户已被删除
发表于 2004-2-12 00:19:10 | 显示全部楼层 来自 德国
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2024-10-1 07:29 , Processed in 0.043424 second(s), 11 queries , Gzip On, MemCache On.
