查看: 1013|回复: 2
【讨论】用于求解的key文件
发表于 2004-2-25 11:49:58 | 显示全部楼层 |阅读模式 来自 湖北武汉
以下是前处理完后生成的key文件;后面附一张图片。
*   DEFORM 2D KEYWORD FILE V7.20 (MOTIF PRE)
*  Process Definition         参数定义
TITLE
DEFORM SIMULATION
CURSIM       1
SIMNAM
OPERATION 1
UNIT         1
STYPE        1
SMODE        1
GEOTYP       1
MESHNO       1
TNOW     0.0000000E+00   0.0000000E+00 0.0E+00
TRANS        0      1      0      0      0
HTMTHD       0
*  Stopping & Step Controls        (仿真控制参数)
NSTART      -1
STPINC      10
PDIE         2      0
OSCTRL       0      0      0      0
NSTEP      100
EMAX     0.0000000E+00
TMAX     0.0000000E+00
SMAX     0.0000000E+00  0.0000000E+00
VMIN     0.0000000E+00  0.0000000E+00
LMAX     0.0000000E+00  0.0000000E+00
STPDEF       1
DEMAX    0.0000000E+00
DTMAX    0.1000000E+00
SLDERR   0.0000000E+00
DTPMAX   0.0000000E+00  0.0000000E+00  0.0000000E+00  0.0000000E+00  0.0000000E+00
DVMAX    0.0000000E+00  0.0000000E+00
MDSOBJ     0    0    0   0.0000000E+00
CNTERR     0   0.0000000E+00
*  Iteration Controls          迭代控制
CVGERR   0.1000000E-02  0.1000000E-01
INIGES       1
ITRMTH       1
ITRMXD     200
DEFBWD       1
SOLMTD       1
SOLMTT       1
ITRMXT     200
TMPBWD       1
LATENT       0
*  Processing Conditions
GEOERR   0.1000000E-05  0.1000000E-03
PENINF   0.1000000E+10
UNTE2H   0.1000000E+01
TINTGF   0.7500000E+00
BLZMAN   0.5669000E-10
ENVTMP     0   0.2000000E+02
CNVCOF     0   0.2000000E-01
ENVMPR   0.1260000E-08
ENVMPT   0.8800000E-14
EHRATE   0.0000000E+00
ENVATM     0   0.1690000E+01
ACVCOF     0   0.2500000E-03
*  Property Data of Material     1  (材料参数)
MTNAME     1
AISI-304,COLD [70F(20C)]
FRAE2H     1   0.9000000E+00
FPERV      1   0.0000000E+00
FRCMOD     1    0    0.0000E+00   0.0000E+00   0.0000E+00   0.0000E+00
FSTRES     1    2
   3  2  1
  0.1000000E+00  0.7000000E+00  0.2000000E+01
  0.1000000E+01  0.1000000E+03
  0.6800000E+02
  0.5287528E+02  0.1699458E+03  0.1740000E+03  0.5287528E+02  0.1699458E+03
  0.1742900E+03
YOUNG      1    0  0.2100000E+06
POISON     1    0  0.2900000E+00
EXPAND     1    0  0.0000000E+00
THRCND     1    0  0.0000000E+00
HEATCP     1    0  0.0000000E+00
EMSVTY     1    0  0.0000000E+00
LTHEAT     1   0.0000000E+00
TMPSOL     1   0.0000000E+00
TMPLIQ     1   0.0000000E+00
HDNPHA     1    0  0.0000000E+00
JOMINY     1    1    1    1
  0.0000000E+00
  0.0000000E+00
  0.0000000E+00
MSTMTR     1    0
DIFCOE     1    0  0.0000000E+00
ELRST      1    0  0.0000000E+00
UTSDAT     1    0  0.0000000E+00
HDNRUL     1    0
PMEAB      1    0  0.0000000E+00
PMITT      1    0  0.0000000E+00
*  Inter-Material Data
*  Inter-Material Data for     1 and     1
*  Data for Object #     1     (对象1的参数)
OBJNAM       1
blank
OBJTYP       1      2
AVGSTR       1   0.1000000E+01
LMTSTR       1   0.1000000E-01
ZSTR         1      0   0.0000000E+00
PENVOL       1   0.1000000E+07  0.1000000E+01
REFTMP       1   0.2000000E+02
TMPLMT       1   0.0000000E+00
ELPSOL       1       0
OTPRNG       1       0   0.0000000E+00  0.0000000E+00
MOVCTL       1      1      0   0.0000000E+00  0.0000000E+00
STROKE       1   0.0000000E+00  0.0000000E+00
RZ           1   1081
      2  0.5767196E+00  0.0000000E+00
      3  0.1153416E+01  0.0000000E+00
   1080  0.5993028E+01  0.4000000E+02
   1081  0.4994124E+01  0.4000000E+02
BCCDEF      1   113     0     2  (边界条件)
     1     1     0
    27     0    -3
  1080     0    -2
  1081     0    -2
NDTMP       1      0  0.2000000E+02      2  (节点温度)
ELMCON       1   1011
         1        28         1         2        29
         2        55        28        29        56
      1010        81       108       107        80
      1011        54        81        80        53
RMDPTH       1   0.0000000E+00
RMSTRK       1   0.0000000E+00
RMTIME       1   0.0000000E+00
RMSTEP       1      0
MGNELM       1   1000
MGTELM       1   0.4000000E+01
MGSIZR       1   0.3000000E+01
MGWCUV       1   0.1936047E+00
MGWTMP       1   0.0000000E+00
MGWSTN       1   0.1936047E+00
MGWSTR       1   0.1936047E+00
MGWUSR       1   0.4191860E+00
MGGRID       1     25     25
MGERR        1   0.1000000E-01  0.3200000E+02
MGUSER       1      1      4   0.3000000E+01  0.0000000E+00  0.0000000E+00
      1 -0.6612548E+01  0.9530355E+01
      2 -0.6689864E+01 -0.1374185E+02
      3  0.1650503E+02 -0.1420575E+02
      4  0.2114400E+02  0.1123131E+02
MGUSER       1      2      4   0.2000000E+01  0.0000000E+00  0.0000000E+00
      1 -0.6535232E+01  0.9607672E+01
      2  0.2114400E+02  0.1099936E+02
      3  0.2172388E+02  0.2356326E+02
      4 -0.8352165E+01  0.2456837E+02
MGUSER       1      3      4   0.1000000E+01  0.0000000E+00  0.0000000E+00
      1 -0.8429482E+01  0.2425911E+02
      2  0.2164656E+02  0.2333131E+02
      3  0.2156924E+02  0.4436134E+02
      4 -0.9898491E+01  0.4273770E+02
FRCSTP       1      0
FRCNEL       1      0
FRCMTH       1      0
CRPTIM       1      0
HDNEST       1      0      0   0.0000000E+00  0.0000000E+00
*  Resistance heating data
*  Induction heating data
CSFREQ       1      0   0.0000000E+00
VOLCRG       1      0   0.0000000E+00
UENAME       1      2
UNNAME       1      2
MATAXI      1      0      1  0.0000000E+00
*  Data for Object #     2 3
(本例中对象2,3为模具,数据都类似1;与考不考虑模具的温度、应力也有关系)
 楼主| 发表于 2004-2-25 11:56:26 | 显示全部楼层 来自 湖北武汉
回复: 【讨论】用于求解的key文件
这是计算前后的图片
 楼主| 发表于 2004-2-25 11:57:48 | 显示全部楼层 来自 湖北武汉
Re: 【讨论】用于求解的key文件
计算后的图
GMT+8, 2026-1-7 04:47 , Processed in 0.032846 second(s), 15 queries , Gzip On, MemCache On.
