- 1
- 2003-12-31
楼主 |
发表于 2004-3-24 20:52:41
来自 英国
To wjytj, thanks!!!
Hi, wjytj. Now I have successfully tranfered the .sel file into .fil file that Patran can read! And at the same time, I want to write your command I have done in details for the potential person who will use this command:
In my example, I want to transfer abc.sel into abc.fil
the command line in my UINX system will be like this:
abq631 job=abc convert=select, NOT job=abe.sel
Note: the names of all the other file created by Abaqus, which related with abc.sel, should be not changed, that is to say, the other file's names should be such as abc.odb, abc.sta, etc. For abaqus, by default change the abe.sel into abc.fil.
Another thing i want to say is that for the version of Patran 2003, it has been devveloped the function to read .odb file directly from abqqus. I am just knowing this thing today, hehe!
Any thanks to wjytj. !!!( Can you tell me where you see the commands for abaqus and I really want to know more about the command line really!) |
