- 3
- 2004-2-14
楼主 |
发表于 2004-4-10 13:27:53
来自 湖北襄阳
回复: 【分享】Mastercam软件的后置处理文件及其设定方法
# Motion NC output 运动 NC 输出
#绝对方式输出的变量为 xabs, yabs, zabs.
#增量方式输出的变量为 xinc, yinc, zinc.
prapidout #输出直线运动的NC指令 - 快速
pcan1, pbld, n, sgplane, `sgcode, sgabsinc, pccdia,
pxout, pyout, pzout, strcantext, scoolant, e
plinout #输出直线运动的NC指令 - 进给
pxout, pyout, pzout, feed, strcantext, scoolant, e
pcirout #输出圆弧插补的NC指令
if arcrad >= max_arc, result = mprint(saxiswarn)
pcan1, pbld, n, sgplane, sgcode, sgabsinc, pccdia,
pxout, pyout, pzout, parc, feed, strcantext, scoolant, e
pcom_moveb #Common motion preparation routines, before
pxyzcout
ps_inc_calc
pncoutput #Movement output
pcom_moveb
comment
pcan
if gcode = zero, prapidout
if gcode = one, plinout
if gcode > one & gcode < four, pcirout
pcom_movea
pcom_movea #Common motion preparation routines, after
pcan2
pe_inc_calc
pdwl_spd #Call from NCI gcode 4
pspindle
comment
if prv_spdir2 <> spdir2, pbld, n, *sm05, e
if prv_speed <> speed | prv_spdir2 <> spdir2,
pbld, n, *speed, *spindle, pgear, e
pcan
if fmtrnd(dwell), pcan1, pbld, n, *sgcode, *dwell, strcantext, e
else, pcan1, pbld, n, strcantext, e
pcan2
prapid #输出直线运动的NC指令 - 快速
pncoutput
pzrapid #输出直线运动的NC指令 - 快速 Z only
pncoutput
plin #输出直线运动的NC指令 - 进给
pncoutput
pz #输出直线运动的NC指令 - 进给 Z only
pncoutput
pmx #输出NCI向量的NC指令
pncoutput
pcir #输出圆弧插补的NC指令
pncoutput
# Motion output components 运动输出组成
pbld #Canned text - 单节删除
if bld, '/'
pfbld #强制 - 单节删除
pccdia #切削补偿
#Force Dxx#
if prv_cc_pos <> cc_pos & cc_pos, prv_tloffno = c9k
sccomp
if cc_pos, tloffno
pfxout #Force X axis output
if absinc = zero, *xabs, !xinc
else, *xinc, !xabs
pxout #X output
if absinc = zero, xabs, !xinc
else, xinc, !xabs
pfyout #Force Y axis output
if absinc = zero, *yabs, !yinc
else, *yinc, !yabs
pyout #Y output
if absinc = zero, yabs, !yinc
else, yinc, !yabs
pfzout #Force Z axis output
if absinc = zero, *zabs, !zinc
else, *zinc, !zabs
pzout #Z output
if absinc = zero, zabs, !zinc
else, zinc, !zabs
parc #选择圆弧输出格式
if arcoutput = zero,
#圆弧输出为 IJK
i, j, k
else,
#圆弧输出为 R
if abs(sweep)<=180 | arcoutput=one, result = nwadrs(srad, arcrad)
else, result = nwadrs(srminus, arcrad)
*arcrad
# Drilling 钻孔
pdrlcommonb #Canned Drill Cycle common call, before
if gcode = 81,
result = newfs (two, zinc)
if drillcyc = three, drlgsel = fsg1(-ss) + drillcyc * two
else, drlgsel = fsg2(dwell) + drillcyc * two
if initht <> refht, drillref = zero
else, drillref = one
prv_refht_a = c9k
prv_refht_i = c9k
z = depth
prv_zia = initht
feed = fr_pos
prv_dwell = zero
@dwell
pcom_moveb
comment
pcan
prdrlout #R drill position
refht_a = refht
refht_i = refht - initht
if absinc = zero, refht_a, !refht_i
else, refht_i, !refht_a
pdrill #钻孔固定循环
pdrlcommonb
pcan1, pbld, n, *sgdrlref, *sgdrill, pxout, pyout, pfzout,
prdrlout, dwell, *feed, strcantext, e
pcom_movea
ppeck #啄式钻孔固定循环
pdrlcommonb
prdrlout, *peck1, *feed, strcantext, e
pcom_movea
pchpbrk #断屑固定循环
pdrlcommonb
pcom_movea
ptap #攻螺纹固定循环
pdrlcommonb
prdrlout, *feed, strcantext, e
pcom_movea
pbore1 #镗孔固定循环 #1
pdrlcommonb
pcom_movea
pbore2 #镗孔固定循环 #2
pdrlcommonb
pcom_movea
pmisc1 #Canned Misc #1 Cycle
pdrlcommonb
prdrlout, shftdrl, dwell, *feed, strcantext, e
pcom_movea
pmisc2 #Canned Misc #2 Cycle (User Option)
pdrill
pdrill_2 #Canned Drill Cycle, additional points
pdrlcommonb
pcan1, pbld, n, pxout, pyout, pzout, prdrlout, dwell,
feed, strcantext, e
pcom_movea
ppeck_2 #Canned Peck Drill Cycle
pdrill_2
pchpbrk_2 #Canned Chip Break Cycle
pdrill_2
ptap_2 #Canned Tap Cycle
pdrill_2
pbore1_2 #Canned Bore #1 Cycle
pdrill_2
pbore2_2 #Canned Bore #2 Cycle
pdrill_2
pmisc1_2 #Canned Misc #1 Cycle
pdrill_2
pmisc2_2 #Canned Misc #2 Cycle
pdrill_2
pdrlcst #自定义钻孔循环 8 - 19 (user option)
#Use this postblock to customize drilling cycles 8 - 19
pdrlcommonb
"CUSTOMIZABLE DRILL CYCLE ", pfxout, pfyout, pfzout, e
pcom_movea
pdrlcst_2 #自定义钻孔循环 8 - 19, additional points (user option)
pdrlcommonb
pcom_movea
pcanceldc #Cancel canned drill cycle
result = newfs (three, zinc)
z = initht
prv_zia = initht
pxyzcout
!zabs, !zinc
prv_gcode = zero
pbld, n, "G80", e |
