- 42
- 2002-9-17
Programs Description
GRESP Generate the response spectra of a linear SDOF system to base excitation.
gresp.for
gresp.exe
gresp.wri
gresp.in
p7accl.in
LRESP Generate the displacement response spectra of a SDOF system to arbitrary loading. lresp.for
lresp.exe
lresp.wri
lresp.in
MODES Compute the response of a MDOF system using Mode-Superposition. System must be linear and have proportional damping. modes.for
modes.exe
modes.wri
modes.in
NEWB Simulate the response of a MDOF system using Newmark-Beta time integration to directly integrate the coupled ordinary differential equations of motion at specified time intervals. newb.for
newb.exe
newb.wri
newb.in
PLAS Compute the elasto-plastic response of a SDOF system to an arbitrary applied load including the nonlinear behavior of the system caused by displacements beyond the elastic limit of the material. plas.for
plas.exe
plas.wri
plas.in
NRIDGE Northridge earthquake record. nridge.dat
FFT Compute the fast Fourier transform of a timeseries or the inverse transform of spectral components (real and/or complex). fft.for fft.exe fft.txt
UPCROSS Determines the zero upcrossing waves from a timeseries of the free surface. upcross.for upcross.exe upcross.txt input.dat
LWT Compute?the free surface elevation, horizontal and vertical velocity, horizontal and vertical acceleration as a function of time at a given horizontal and vertical location. lwt.for lwt.exe lwt.txt
STOKES5 Compute?the free surface elevation, horizontal and vertical velocity, horizontal and vertical acceleration as a function of time at a given horizontal and vertical location.? stokes5.for stokes5.exe
CNOIDAL Compute free surface elevation, horizontal and vertical velocity, and horizontal acceleration as a function of time at a given vertical location. cnoidal.for cnoidal.exe |
