查看: 196|回复: 5
[2. C/C++/C#] 【求助】紧急求助!!
shukai_zhao 该用户已被删除
发表于 2004-6-6 20:54:49 | 显示全部楼层 |阅读模式 来自 同济大学
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2004-6-7 08:39:37 | 显示全部楼层 来自 香港
回复: 【求助】紧急求助!!
只见过fortran编的
发表于 2004-6-7 21:38:26 | 显示全部楼层 来自 美国
回复: 【求助】紧急求助!!
http://caswww.colorado.edu/~charbel/FEM-OO-C++.html
FEM: A C++ Object Oriented Finite Element Module
Program Description:
FEM is a C++ Object Oriented Finite Element Code Demonstrator. The source code contains C++ classes that represent Finite Element objects such as nodes, elements, connectivities, and degrees of freedom as well as Mathematical objects such as vectors, matrices, and sparse matrices. These C++ objects can be (and are) used to construct specific problem description classes for linear statics, linear dynamics, and modal analysis.  The source code also contains three different equation solvers: a skyline, a frontal, and a Preconditioned Conjugate Gradient (PCG) solver.
The input to FEM is processed by a text file and a parsing program generated by lex and yacc. Example input files and reference solutions are included in this code release.
FEM is public domain software: anyone is welcome to download it.
shukai_zhao 该用户已被删除
 楼主| 发表于 2004-6-8 17:34:29 | 显示全部楼层 来自 同济大学
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2004-6-8 18:21:20 | 显示全部楼层 来自 大连理工大学
回复: 【求助】紧急求助!!
我也向上去看看,怎么连不上去呢?看地址象是教育网的,我也是,怎么回事?有没有ftp可以下载?谢谢~
发表于 2004-6-9 09:47:34 | 显示全部楼层 来自 湖北武汉
回复: 【求助】紧急求助!!
是教育网的
但是是外国的教育网
你可以找一个代理上的
我可以上的
但是附件有点大,接近5M的
没办法上传
还是自己找代理去看看吧
^_^
GMT+8, 2026-1-6 10:03 , Processed in 0.033143 second(s), 15 queries , Gzip On, MemCache On.
