查看: 112|回复: 1
这句话,没理解它的意思,高手解释一下吧
发表于 2004-6-25 21:12:07 | 显示全部楼层 |阅读模式 来自 黑龙江哈尔滨
Continuation of an amplitude reference in subsequent steps
If a boundary condition, load, or predefined field refers to an amplitude curve and the prescribed condition is not redefined in subsequent steps, the following rules apply:
If the associated *AMPLITUDE was given in terms of total time, the prescribed condition continues to follow the *AMPLITUDE definition.
If the AMPLITUDE parameter was not used or if the *AMPLITUDE was given in terms of step time, the prescribed condition remains constant at the magnitude associated with the end of the previous step.
发表于 2004-6-26 14:57:12 | 显示全部楼层 来自 陕西西安
回复: 这句话,没理解它的意思,高手解释一下吧
如果你的边界条件,载荷或者一些场变量的定义与amplitude有关,并且在此后的step中没有重新定义这些条件的话,程序会按照如下方式处理:
(1),如果amplitude得定义是作用于整个分时过程中的,那么在此后的时间中所有相关的条件仍然按照amplitude变化
(2)   如果未使用amplitude或者他的定义是与step相关的,那么各种相关条件的实际情况与前一个step结束时的状况相同,并保持不变
GMT+8, 2024-10-1 19:36 , Processed in 0.055544 second(s), 13 queries , Gzip On, MemCache On.
