- 2004-3-15
INCREMENT 1 STARTS. ATTEMPT NUMBER 1, TIME INCREMENT 0.100
***WARNING: SOLVER PROBLEM. NUMERICAL SINGULARITY WHEN PROCESSING NODE 1
INSTANCE XDZHLG-1 D.O.F. 3 RATIO = 2.53969E+13
INSTANCE XDZHLG-1 D.O.F. 6 RATIO = 2.65853E+14
***WARNING: SOLVER PROBLEM. NUMERICAL SINGULARITY WHEN PROCESSING NODE 1116
INSTANCE PART-4-1 D.O.F. 2 RATIO = 6.95591E+12
***WARNING: SOLVER PROBLEM. NUMERICAL SINGULARITY WHEN PROCESSING NODE 912
INSTANCE PART-2-1 D.O.F. 2 RATIO = 3.42636E+12
INSTANCE PART-2-1 D.O.F. 3 RATIO = 5.32039E+11
INSTANCE PART-16-1 D.O.F. 1 RATIO = 9.40600E+13
INSTANCE PART-16-1 D.O.F. 2 RATIO = 4.38411E+12
INSTANCE PART-16-1 D.O.F. 3 RATIO = 6.43731E+12
INSTANCE PART-16-1 D.O.F. 5 RATIO = 4.66639E+12
INSTANCE PART-16-1 D.O.F. 6 RATIO = 1.02396E+14
***WARNING: THE SYSTEM MATRIX HAS 3 NEGATIVE EIGENVALUES.
IN AN EIGENVALUE EXTRACTION STEP THE NUMBER OF NEGATIVE EIGENVALUES IS
EQUAL TO THE NUMBER OF EIGENVALUES BELOW THE CURRENT SHIFT POINT.
THIS MAY BE USED TO CHECK THAT EIGENVALUES HAVE NOT BEEN MISSED.
NOTE: THE LANCZOS EIGENSOLVER APPLIES AN INTERNAL SHIFT WHICH WILL
RESULT IN NEGATIVE EIGENVALUES.
IN A DIRECT-SOLUTION STEADY-STATE DYNAMIC ANALYSIS, NEGATIVE
EIGENVALUES ARE EXPECTED. A STATIC ANALYSIS CAN BE USED TO VERIFY THAT THE SYSTEM IS STABLE.
IN OTHER CASES, NEGATIVE EIGENVALUES MEAN THAT THE SYSTEM MATRIX IS NOT
 OSITIVE DEFINITE:
FOR EXAMPLE, A BIFURCATION (BUCKLING) LOAD MAY HAVE BEEN EXCEEDED.
NEGATIVE EIGENVALUES MAY ALSO OCCUR IF QUADRATIC ELEMENTS ARE
USED TO DEFINE CONTACT SURFACES.
***WARNING: Solver problem. Numerical singularity when processing D.O.F. 5 of
1 nodes. The nodes have been identified in node set
WarnNodeSolvProbNumSing_5_1_1_1_1.
***WARNING: Solver problem. Numerical singularity when processing D.O.F. 1 of
WarnNodeSolvProbNumSing_1_1_1_1_1.
***WARNING: Solver problem. Numerical singularity when processing D.O.F. 2 of
3 nodes. The nodes have been identified in node set
WarnNodeSolvProbNumSing_2_1_1_1_1.
***WARNING: Solver problem. Numerical singularity when processing D.O.F. 6 of
2 nodes. The nodes have been identified in node set
WarnNodeSolvProbNumSing_6_1_1_1_1.
***WARNING: Solver problem. Numerical singularity when processing D.O.F. 3 of
WarnNodeSolvProbNumSing_3_1_1_1_1.
***WARNING: CONTACT SURFACES ASSEMBLY_SURF-6 and ASSEMBLY_SURF-9 NODE NUMBER
10598 INSTANCE PART-2-1 IS OVERCLOSED BY 503.25 WHICH IS TOO
SEVERE--CUTBACK WILL RESULT. YOU MAY WANT TO CHANGE THE VALUE OF
HCRIT (16.750) ON THE *CONTACT PAIR OPTION.
10606 INSTANCE PART-2-1 IS OVERCLOSED BY 868.97 WHICH IS TOO
10591 INSTANCE PART-2-1 IS OVERCLOSED BY 2118.7 WHICH IS TOO
10604 INSTANCE PART-2-1 IS OVERCLOSED BY 2649.2 WHICH IS TOO
3915 INSTANCE PART-2-1 IS OVERCLOSED BY 4402.8 WHICH IS TOO
10593 INSTANCE PART-2-1 IS OVERCLOSED BY 3025.6 WHICH IS TOO
10594 INSTANCE PART-2-1 IS OVERCLOSED BY 1590.8 WHICH IS TOO
3911 INSTANCE PART-2-1 IS OVERCLOSED BY 117.24 WHICH IS TOO
3912 INSTANCE PART-2-1 IS OVERCLOSED BY 1632.2 WHICH IS TOO
3913 INSTANCE PART-2-1 IS OVERCLOSED BY 2950.5 WHICH IS TOO
3914 INSTANCE PART-2-1 IS OVERCLOSED BY 3912.7 WHICH IS TOO
817 INSTANCE PART-2-1 IS OVERCLOSED BY 4362.2 WHICH IS TOO
10592 INSTANCE PART-2-1 IS OVERCLOSED BY 2833.5 WHICH IS TOO
3916 INSTANCE PART-2-1 IS OVERCLOSED BY 4036.9 WHICH IS TOO
10599 INSTANCE PART-2-1 IS OVERCLOSED BY 2488.9 WHICH IS TOO
***WARNING: CONTACT SURFACES ASSEMBLY_SURF-10 and ASSEMBLY_SURF-5 NODE NUMBER
1494 INSTANCE PART-4-1 IS OVERCLOSED BY 4381.5 WHICH IS TOO
HCRIT (20.763) ON THE *CONTACT PAIR OPTION.
1492 INSTANCE PART-4-1 IS OVERCLOSED BY 2031.6 WHICH IS TOO
1493 INSTANCE PART-4-1 IS OVERCLOSED BY 3470.5 WHICH IS TOO
1495 INSTANCE PART-4-1 IS OVERCLOSED BY 4625.3 WHICH IS TOO
1496 INSTANCE PART-4-1 IS OVERCLOSED BY 4165.0 WHICH IS TOO
1497 INSTANCE PART-4-1 IS OVERCLOSED BY 3070.5 WHICH IS TOO
1506 INSTANCE PART-4-1 IS OVERCLOSED BY 1996.5 WHICH IS TOO
1507 INSTANCE PART-4-1 IS OVERCLOSED BY 1988.2 WHICH IS TOO
1498 INSTANCE PART-4-1 IS OVERCLOSED BY 1508.6 WHICH IS TOO
1508 INSTANCE PART-4-1 IS OVERCLOSED BY 815.69 WHICH IS TOO
1505 INSTANCE PART-4-1 IS OVERCLOSED BY 836.38 WHICH IS TOO
***WARNING: CONTACT SURFACES ASSEMBLY_SURF-4 and ASSEMBLY_SURF-11 NODE NUMBER
11452 INSTANCE PART-2-1 IS OVERCLOSED BY 2767.8 WHICH IS TOO
HCRIT (16.356) ON THE *CONTACT PAIR OPTION.
11433 INSTANCE PART-2-1 IS OVERCLOSED BY 1138.0 WHICH IS TOO
931 INSTANCE PART-2-1 IS OVERCLOSED BY 888.77 WHICH IS TOO
4265 INSTANCE PART-2-1 IS OVERCLOSED BY 2490.3 WHICH IS TOO
11444 INSTANCE PART-2-1 IS OVERCLOSED BY 500.78 WHICH IS TOO
11431 INSTANCE PART-2-1 IS OVERCLOSED BY 2081.8 WHICH IS TOO
11432 INSTANCE PART-2-1 IS OVERCLOSED BY 2883.5 WHICH IS TOO
928 INSTANCE PART-2-1 IS OVERCLOSED BY 4360.1 WHICH IS TOO
4263 INSTANCE PART-2-1 IS OVERCLOSED BY 4368.0 WHICH IS TOO
4264 INSTANCE PART-2-1 IS OVERCLOSED BY 3712.0 WHICH IS TOO
4257 INSTANCE PART-2-1 IS OVERCLOSED BY 4034.3 WHICH IS TOO
11451 INSTANCE PART-2-1 IS OVERCLOSED BY 2486.7 WHICH IS TOO
11430 INSTANCE PART-2-1 IS OVERCLOSED BY 2116.7 WHICH IS TOO
***WARNING: CONTACT SURFACES ASSEMBLY_SURF-3 and ASSEMBLY_SURF-12 NODE NUMBER
974 INSTANCE PART-2-1 IS OVERCLOSED BY 4361.5 WHICH IS TOO
HCRIT (16.744) ON THE *CONTACT PAIR OPTION.
4414 INSTANCE PART-2-1 IS OVERCLOSED BY 3794.5 WHICH IS TOO
4415 INSTANCE PART-2-1 IS OVERCLOSED BY 2769.6 WHICH IS TOO
11732 INSTANCE PART-2-1 IS OVERCLOSED BY 2816.6 WHICH IS TOO
11740 INSTANCE PART-2-1 IS OVERCLOSED BY 2265.1 WHICH IS TOO
4416 INSTANCE PART-2-1 IS OVERCLOSED BY 1410.6 WHICH IS TOO
11733 INSTANCE PART-2-1 IS OVERCLOSED BY 450.24 WHICH IS TOO
11728 INSTANCE PART-2-1 IS OVERCLOSED BY 1965.6 WHICH IS TOO
11729 INSTANCE PART-2-1 IS OVERCLOSED BY 2677.2 WHICH IS TOO
11730 INSTANCE PART-2-1 IS OVERCLOSED BY 3466.4 WHICH IS TOO
11738 INSTANCE PART-2-1 IS OVERCLOSED BY 1088.1 WHICH IS TOO
1777 INSTANCE PART-2-1 IS OVERCLOSED BY 575.15 WHICH IS TOO
11731 INSTANCE PART-2-1 IS OVERCLOSED BY 3158.7 WHICH IS TOO
4413 INSTANCE PART-2-1 IS OVERCLOSED BY 4687.7 WHICH IS TOO
***ERROR: TIME INCREMENT NEEDED IS LESS THAN THE MINIMUM SPECIFIED. THE
ANALYSIS TERMINATES. |
