查看: 220|回复: 1
[10. Others] 【求助】Jeffjia
发表于 2003-1-20 09:39:55 | 显示全部楼层 |阅读模式 来自 四川成都
谢谢你的答复,能否举一个简单的例子:FORTRAN源程序代码,比如加法器,将它改变成动态连接库DLL文件,然后用VC调用?gm_mei@sina.com
发表于 2003-1-20 10:13:51 | 显示全部楼层 来自 重庆南岸区
回复: 【求助】Jeffjia
VISUAL C/C++ CALLING VISUAL FORTRAN DLL EXAMPLE
The following is an example of mixed-language programming with a Microsoft Visual C/C++ main program calling a Visual Fortran routine in a DLL.  You can also do it without the DLL by adding the Fortran source to the same project as the C/C++ source (and omitting the DLL-related directives).  The instructions below assume you have Microsoft Visual C/C++ 5.0 or 6.0 installed and sharing the Developer Studio environment with Visual Fortran (requires the same major release of Visual Fortran and Visual C/++, for example V5 of both or V6 of both.)
Create a "Fortran Console Application" (V6) or "Win32 Console Application" (V5) project for the main program, call it VC-Example.  In the V6 project wizard, indicate that an empty project should be created.
In this project, create a C/C++ source file named "cmain" (the file type will default to .cpp) with the following code:
/* Main program written in C++ that calls a Fortran DLL */
#include <stdio.h>
#include <string.h>
/* Declare the Fortran routine. The following items are of note:
   - The "C" attribute prevents C++ name mangling  Remove it
     if the file type is .c
   - The dllimport specification is required
   - Fortran routines use the _stdcall interface by default
   - Fortran character arguments have a hidden length
     argument following the address
   - Routine name must be in uppercase to match Fortran.
extern "C" __declspec(dllimport) void _stdcall DLL_ROUT (
    int *INT_ARG,
    char *STR_IN,
  int STR_IN_LEN,
  char *STR_OUT,
  int STR_OUT_LEN);
void main (int argc, char *argv[])
    char instring[40];
    char outstring[40];
    int intarg;
    strcpy(instring,"Testing...");
    intarg = 123;
    /* Call Fortran routine - pass intarg by reference,
       pass length of outstring explicitly */
    DLL_ROUT(&intarg,instring,strlen(instring),outstring,40);
    printf("%s\n",outstring);
Create a new "Fortran Dynamic Link Library" project, check "Add to current workspace" and "Dependency of".  Call it VF-DLL.
In this project, create a Fortran Free-form source file named "dll_rout" (the file type will default to .f90) as follows:
! Fortran part of a C-Fortran DLL example. This
! routine DLL_ROUT is called from a C executable program.
SUBROUTINE DLL_ROUT (INT_ARG, STR_IN, STR_OUT)
IMPLICIT NONE
! Specify that DLL_ROUT is exported to a DLL
!DEC$ ATTRIBUTES DLLEXPORT :: DLL_ROUT
INTEGER INT_ARG
CHARACTER*(*) STR_IN, STR_OUT
! This routine converts INT_ARG to a decimal string.
! appends the string value to STR_IN and stores it
! in STR_OUT. A trailing NUL is added to keep C
! happy.
! Note that there are implicit length arguments following
! the addresses of each CHARACTER argument.
CHARACTER*5 INT_STR
WRITE (INT_STR,'(I5.5)')INT_ARG
STR_OUT = STR_IN // INT_STR // CHAR(0)
RETURN
END
Select Build..Set Active Configuration and set your executable project (VC-Example) as active. Click on the Build button. It should build the Fortran code first, then the C code and link it. (Note that because the DLL project is a subproject, it is built first AND its .LIB is automatically
included with the main program.)
Manually copy the VF-DLL.DLL file from the \Debug (or \Release) subdirectory of the DLL project to the directory containing the .EXE file.
Run the program. It should display "Testing...00123" in the console window
呵呵,还是不要求助JeffJia得好,让大家一起讨论好吗!
GMT+8, 2024-11-2 05:28 , Processed in 0.051055 second(s), 13 queries , Gzip On, MemCache On.
