- 1
- 2005-1-14
楼主 |
发表于 2005-2-24 11:07:38
来自 黑龙江哈尔滨
Re:小弟新手,请教!!
我是照着这个弄得:
INSTALL NOTES:
1.Install FLOTHERM, then copy flo.lic to c:\flexlm
set enviroment string: FloLIC = c:\flexlm\flow.lic
2.Open a command line box, run: lmutil lmhostid,
write down your hostid(in fact it's your NIC's MAC address).
3.Edit c:\flexlm\flow.lic, find all HOSTID=112233445566,
replace 112233445566 with your current hostid found above, then save it.
4.Run RORFLO41.exe to apply the patch.
5.Start LAdmin, Select "OpenInventor" from the Product list, Click in the Host ID edit window to get the computer ID,
Type in the version number, expiration date, key, info string. Click Add, then click Apply, then click Exit.
Now open inventor 2.6 is licensed and flomotion will run.
Product: OpenInventor
Vserion: 2.6
Expries: 1-Jan-0
Infomation: ROR
Key: Use's ROR's Keygen to generate the serial number
可第四步弄不过去啊她说winpatch errors
各位帮帮忙 |
