- 5
- 2005-3-30
我的K文件和书中的一样怎么就是有错呀
$ MATERIAL DEFINITIONS $
*MAT_JOHNSON_COOK
1 7.83 0.77
7.920e-3 5.100e-03 0.260 0.140e-01 1.030.1793e+04 294 0.100e-05
0.477e-05 -9.00e+00 3.00 0.00 5.00 0.00 0.00 0.00
0.00
*EOS_GRUNEISEN
1 0.4569 1.490 0.00 0.00 2.17 0.46 0.00
1.00
*MAT_JOHNSON_COOK
2 7.83 0.77
0.477e-05 -9.00e+00 3.00 0.00 0.80 0.00 0.00 0.00
0.00
*EOS_GRUNEISEN
2 0.4569 1.490 0.00 0.00 2.17 0.46 0.00
1.00
*MAT_JOHNSON_COOK
3 7.83 0.77
0.00
*EOS_GRUNEISEN
3 0.4569 1.490 0.00 0.00 2.17 0.46 0.00
1.00
错误信息为:
*** Error line number 2283 contains improperly formatted data
(This is line# 2283 of file C:\DOCUME~1\kitch\PENETR~1.K)
----------------------------------------------------------------line# 2283 -----
*** Error reading *MAT_JOHNSON_COOK card.
*** Error in keyword command:
0.00
Check near line # 2284
(This is line# 2284 of file C:\DOCUME~1\kitch\PENETR~1.K)
*** Error line number 2292 contains improperly formatted data
(This is line# 2292 of file C:\DOCUME~1\kitch\PENETR~1.K)
----------------------------------------------------------------line# 2292 -----
0.00
Check near line # 2293
(This is line# 2293 of file C:\DOCUME~1\kitch\PENETR~1.K)
*** Error line number 2301 contains improperly formatted data
(This is line# 2301 of file C:\DOCUME~1\kitch\PENETR~1.K)
----------------------------------------------------------------line# 2301 -----
0.00
Check near line # 2302
(This is line# 2302 of file C:\DOCUME~1\kitch\PENETR~1.K)
expanding memory to 283728
*** Error line number 4329 contains improperly formatted data
(This is line# 4329 of file C:\DOCUME~1\kitch\PENETR~1.K)
----------------------------------------------------------------line# 4329 -----
*CONTROL_ENERGY
reading *CONTROL_CONTACT
1 2 2 1
Check near line # 4330
(This is line# 4330 of file C:\DOCUME~1\kitch\PENETR~1.K)
expanding memory to 317839
*** Error Set ID= 1 contains node ID= 5311
which is undefined under *NODE input.
CHECKING MATERIAL INPUT DATA Part ID= 1
*** Error part ID 1 of system MAIN with
section ID 1 of system MAIN and
material ID 1 of system MAIN does not exist.
This is part no. 1 in the order of input. |
