查看: 310|回复: 8
我做的一个热流耦合的算例,请大家看看是否合理
发表于 2005-4-11 19:44:34 | 显示全部楼层 |阅读模式 来自 黑龙江哈尔滨
计算的是流体绕流固体的情况
A1:固体,导热系数为10
A2:流体,导热系数、比热、粘性、密度均为5
边界条件:
L1:热流密度=100
L5,L6:VY=0
L9:Vx=50,Vy=0,T=10
L7:P=0
L8:自由边界
 楼主| 发表于 2005-4-11 19:45:08 | 显示全部楼层 来自 黑龙江哈尔滨
Re:我做的一个热流耦合的算例,请大家看看是否合理
 楼主| 发表于 2005-4-11 19:46:09 | 显示全部楼层 来自 黑龙江哈尔滨
温度场结果:
 楼主| 发表于 2005-4-11 19:48:28 | 显示全部楼层 来自 黑龙江哈尔滨
速度场:
 楼主| 发表于 2005-4-11 19:54:02 | 显示全部楼层 来自 黑龙江哈尔滨
log文件,还没有时间整理出来
/BATCH
/COM,ANSYS RELEASE  8.0    UP20030930       09:11:02    04/09/2005
/NOPR
/PMETH,OFF,0
KEYW,PR_SET,1
KEYW,PR_STRUC,0
KEYW,PR_THERM,0
KEYW,PR_FLUID,0
KEYW,PR_ELMAG,0
KEYW,MAGNOD,0
KEYW,MAGEDG,0
KEYW,MAGHFE,0
KEYW,MAGELC,0
KEYW,PR_MULTI,0
KEYW,PR_CFD,1
/GO
/COM,
/COM,Preferences for GUI filtering have been set to display:
/COM,  FLOTRAN CFD
/PREP7
ET,1,FLUID141
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,KXX,2,,10
K,1,0,0,,
K,2,0,0.04,,
K,3,0,0.06,,
K,4,0,0.1,,
K,5,0.1,0,,
K,6,0.04,0.02,,
K,7,0.06,0.02,,
K,7,0.06,0.02,,
kdel,2,3
K,2,0.02,0.04,,
K,2,0.04,0.02,,
K,3,0.06,0.02,,
K,8,0.1,0.1,,
/replot
kdel,2,3
K,2,0.04,0,,
K,3,0.06,0,,
kplot
FLST,2,4,3
FITEM,2,2
FITEM,2,3
FITEM,2,7
FITEM,2,6
A,P51X
FLST,2,8,3
FITEM,2,1
FITEM,2,2
FITEM,2,6
FITEM,2,7
FITEM,2,3
FITEM,2,5
FITEM,2,8
FITEM,2,4
A,P51X
AATT,       2, ,   1,       0,
CM,_Y,AREA
ASEL, , , ,       1
CM,_Y1,AREA
CMSEL,S,_Y
CMSEL,S,_Y1
AATT,       2, ,   1,       0,
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,AREA
ASEL, , , ,       2
CM,_Y1,AREA
CMSEL,S,_Y
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,KXX,1,,
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,C,1,,
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,DENS,1,,
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,VISC,1,,
CM,_Y,AREA
ASEL, , , ,       1
CM,_Y1,AREA
CMSEL,S,_Y
CMSEL,S,_Y1
AATT,       2, ,   1,       0,
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,AREA
ASEL, , , ,       2
CM,_Y1,AREA
CMSEL,S,_Y
CMSEL,S,_Y1
AATT,       1, ,   1,       0,
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
SMRT,6
MSHAPE,0,2D
MSHKEY,0
FLST,5,2,5,ORDE,2
FITEM,5,1
FITEM,5,-2
CM,_Y,AREA
ASEL, , , ,P51X
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
FLST,5,23,1,ORDE,12
FITEM,5,1
FITEM,5,-4
FITEM,5,9
FITEM,5,-12
FITEM,5,31
FITEM,5,-36
FITEM,5,41
FITEM,5,-42
FITEM,5,45
FITEM,5,-48
FITEM,5,60
FITEM,5,-62
CM,_Y,NODE
NSEL, , , ,P51X
CM,_Y1,NODE
CMSEL,S,_Y
CMDELE,_Y
NREFINE,_Y1, , ,1,1,1,1
CMDELE,_Y1
elist
FINISH
/SOL
lplot
FLST,2,1,4,ORDE,1
FITEM,2,1
/GO
SFL,P51X,HFLUX,100,100
FLST,2,1,4,ORDE,1
FITEM,2,9
/GO
DL,P51X, ,TEMP,10,0
FLST,5,1,4,ORDE,1
FITEM,5,9
CM,_Y,LINE
LSEL,R, , ,P51X
CM,_Y1,LINE
CMSEL,S,_Y
CMDELE,_Y
DL,_Y1, ,VX,50,1
DL,_Y1, ,VY,5,1
CMDELE,_Y1
FLST,5,2,4,ORDE,2
FITEM,5,5
FITEM,5,-6
CM,_Y,LINE
LSEL,R, , ,P51X
CM,_Y1,LINE
CMSEL,S,_Y
CMDELE,_Y
DL,_Y1, ,VY,0,1
CMDELE,_Y1
FLST,5,1,4,ORDE,1
FITEM,5,9
CM,_Y,LINE
LSEL,R, , ,P51X
CM,_Y1,LINE
CMSEL,S,_Y
CMDELE,_Y
DL,_Y1, ,VX,50,1
DL,_Y1, ,VY,0,1
CMDELE,_Y1
FLST,5,1,4,ORDE,1
FITEM,5,7
CM,_Y,LINE
LSEL,R, , ,P51X
CM,_Y1,LINE
CMSEL,S,_Y
CMDELE,_Y
/GO
DL,_Y1, ,PRES,0,1
CMDELE,_Y1
FLDATA1,SOLU,TRAN,0
FLDATA1,SOLU,FLOW,1
FLDATA1,SOLU,TEMP,1
FLDATA1,SOLU,TURB,0
FLDATA1,SOLU,COMP,0
FLDATA1,SOLU,VOF,0
FLDATA1,SOLU,SFTS,0
FLDATA1,SOLU,IVSH,0
FLDATA1,SOLU,SWRL,0
FLDATA1,SOLU,SPEC,0
FLDATA1,SOLU,ALE,0
FLDATA1,SOLU,RDSF,1
FLDATA,ALGR,SEGR,SIMPLEF
FLDATA,ALGR,HFLM,MATX
FLDATA12,PROP,DENS,0
FLDATA13,VARY,DENS,0
FLDATA12,PROP,VISC,0
FLDATA13,VARY,VISC,0
FLDATA12,PROP,COND,0
FLDATA13,VARY,COND,0
FLDATA12,PROP,SPHT,0
FLDATA13,VARY,SPHT,0
FLDATA7,PROT,DENS,CONSTANT
FLDATA8,NOMI,DENS,5,
FLDATA9,COF1,DENS,0
FLDATA10,COF2,DENS,0
FLDATA11,COF3,DENS,0
FLDATA7,PROT,VISC,CONSTANT
FLDATA8,NOMI,VISC,5,
FLDATA9,COF1,VISC,0
FLDATA10,COF2,VISC,0
FLDATA11,COF3,VISC,0
FLDATA12,PROP,IVIS
FLDATA7,PROT,COND,CONSTANT
FLDATA8,NOMI,COND,5,
FLDATA9,COF1,COND,0
FLDATA10,COF2,COND,0
FLDATA11,COF3,COND,0
FLDATA7,PROT,SPHT,CONSTANT
FLDATA8,NOMI,SPHT,5,
FLDATA9,COF1,SPHT,0
FLDATA10,COF2,SPHT,0
FLDATA11,COF3,SPHT,0
FLDATA18,METH,VX,4
FLDATA22,MAXI,VX,100,
FLDATA20,SRCH,VX,12,
FLDATA20A,PGMR,FILL,6,
FLDATA21,CONV,VX,1e-005,
FLDATA23,DELT,VX,1e-010,
FLDATA18,METH,VX,1
FLDATA18,METH,TEMP,4
FLDATA22,MAXI,TEMP,1000,
FLDATA20,SRCH,TEMP,12,
FLDATA20A,PGMR,MODP,0,
FLDATA21,CONV,TEMP,1e-012,
FLDATA23,DELT,TEMP,1e-010,
SOLVE
SOLVE
SOLVE
FINISH
/POST1
/EFACE,1
PLNSOL,TEMP, ,0,
SET,LAST
/EFACE,1
PLNSOL,TEMP, ,0,
FINISH
/SOL
FLDATA24,TURB,MODL,1
FLDATA24,TURB,CMU,0.09,
FLDATA24,TURB,C1,1.44,
FLDATA24,TURB,C2,1.92,
FLDATA24,TURB,SCTK,1,
FLDATA24,TURB,SCTD,1.3,
SOLVE
SOLVE
/POST1
/EFACE,1
PLNSOL,TEMP, ,0,
/VSCALE,1,1,0
PLVECT,V, , , ,VECT,ELEM,ON,0
aplot
/pnum,area,1
aplot
lplot
/pnum,line,1
lplot
FINISH
! /EXIT,NOSAV
 楼主| 发表于 2005-4-11 20:07:11 | 显示全部楼层 来自 黑龙江哈尔滨
看看有什么错误,欢迎大家回帖,
如果没有问题的话,解决共轭传热这类问题就可以这个干了
另,请问斑竹,我怎么可以挣到两个积分?刚好差2个积分:)
发表于 2005-4-12 09:36:11 | 显示全部楼层 来自 黑龙江哈尔滨
我想问一下,为什么你后来要运行下面的命令呢,你是怎么确定这些参数的?
/SOL
 楼主| 发表于 2005-4-12 15:15:25 | 显示全部楼层 来自 黑龙江哈尔滨
先算层流再算湍流,用默认的参数试的
发表于 2005-4-12 16:42:58 | 显示全部楼层 来自 黑龙江哈尔滨
不过从你的命令来看,好像只是设置了湍流的有关参数,但没有打开湍流运算: FLDATA1,SOLU,TURB,1
GMT+8, 2024-9-22 12:49 , Processed in 0.069532 second(s), 17 queries , Gzip On, MemCache On.
