- 1
- 2005-2-18
发表于 2005-4-14 10:16:03
来自 黑龙江哈尔滨
Re:请教一个关于boundary的问题
If the magnitude of the displacement is not specified on the data line, it is assumed to be zero. If the node is constrained in one direction only, the third field should be blank or equal to the second field. For example, to constrain node 103 in the 2-direction (degree of freedom 2) only, any of the following data line formats can be used:
103, 2,2, 0.0
or
103, 2,2
or
103, 2
Boundary conditions on a node are cumulative. Thus, the following input constrains node 101 in both directions 1 and 2:
101, 1
101, 2 |
