查看: 112|回复: 1
帮忙看一下这个错误怎么解决?
发表于 2005-5-22 09:45:52 | 显示全部楼层 |阅读模式 来自 黑龙江哈尔滨
在进行流体热分析时出现下面的警告和错误:
*** WARNING ***                         CP=     39.477   TIME= 09:21:53
Conjugate gradient solver did not meet specified convergence criterion
within specified number of solver sweeps.  Model size may require more
sweeps.  Check debug file for divergence.
  DOF solved was PRES.
*** ERROR ***                           CP=     46.837   TIME= 09:22:00
Maximum number of conjugate gradient iterations exceeded three times.
The run is terminated.
请问各位大侠怎么解决,先谢!
 楼主| 发表于 2005-5-28 15:49:46 | 显示全部楼层 来自 黑龙江哈尔滨
Re:帮忙看一下这个错误怎么解决?
这个问题解决了,对压力的求解采用预条件广义最小残差法(PGMR).
命令:  FLDATA18,METH,PRES,4
           FLDATA22,MAXI,PRES,1000,
           FLDATA20,SRCH,PRES,12,
           FLDATA20A,PGMR,FILL,6,
           FLDATA21,CONV,PRES,1e-012,
           FLDATA23,DELT,PRES,1e-010,
GMT+8, 2024-9-22 11:43 , Processed in 0.033443 second(s), 11 queries , Gzip On, MemCache On.
