查看: 270|回复: 4
温度和应力偶合场 的问题,请教!!先谢了!
发表于 2005-6-16 19:47:28 | 显示全部楼层 |阅读模式 来自 黑龙江哈尔滨
结果不对劲,连混凝土表面都是压应力
!热分析
/filename,themal
/title,themal_analysis  !标题
/PREP7                  !前处理
!定义单元类型
ET,1,SOLID70
!设置材料属性
   !材料1为混凝土
MP,KXX,1,280
MP,C,1,0.976
MP,DENS,1,2500
MAT,1
   !材料2为基础土
MP,KXX,2,300
MP,C,2,1.45
MP,DENS,2,1670
MAT,2
!输入参数
   !输入外界气温表
*DIM,qiwen,TABLE,57,1,1,TIME, , ,  !外界气温表名为qiwen
QIWEN(1,0,1) = 0
QIWEN(1,1,1) = 29
QIWEN(2,0,1) = 0.5
QIWEN(2,1,1) =30
QIWEN(3,0,1) = 1
QIWEN(3,1,1) = 24
QIWEN(4,0,1) =1.5
QIWEN(4,1,1) = 30
QIWEN(5,0,1) =2
QIWEN(5,1,1) = 29
QIWEN(6,0,1) = 2.5
QIWEN(6,1,1) = 28.6
QIWEN(7,0,1) = 3
QIWEN(7,1,1) = 30
QIWEN(8,0,1) =3.5
QIWEN(8,1,1) = 29
QIWEN(9,0,1) = 4
QIWEN(9,1,1) = 28
QIWEN(10,0,1) = 4.5
QIWEN(10,1,1) = 30
QIWEN(11,0,1) =5
QIWEN(11,1,1) = 30
QIWEN(12,0,1) =5.5
QIWEN(12,1,1) = 31
QIWEN(13,0,1) = 6
QIWEN(13,1,1) = 29
QIWEN(14,0,1) = 6.5
QIWEN(14,1,1) = 30
QIWEN(15,0,1) = 7
QIWEN(15,1,1) = 30
QIWEN(16,0,1) = 7.5
QIWEN(16,1,1) = 31
QIWEN(17,0,1) =8
QIWEN(17,1,1) = 29
QIWEN(18,0,1) = 8.5
QIWEN(18,1,1) = 26
QIWEN(19,0,1) =9
QIWEN(19,1,1) = 24
QIWEN(20,0,1) = 9.5
QIWEN(20,1,1) = 26
QIWEN(21,0,1) = 10
QIWEN(21,1,1) = 29
QIWEN(22,0,1) = 10.5
QIWEN(22,1,1) = 29
QIWEN(23,0,1) = 11
QIWEN(23,1,1) = 29
QIWEN(24,0,1) = 11.5
QIWEN(24,1,1) = 29
QIWEN(25,0,1) = 12
QIWEN(25,1,1) = 29
QIWEN(26,0,1) = 12.5
QIWEN(26,1,1) = 29
QIWEN(27,0,1) = 13
QIWEN(27,1,1) = 29
QIWEN(28,0,1) = 13.5
QIWEN(28,1,1) = 29
QIWEN(29,0,1) = 14
QIWEN(29,1,1) = 29
QIWEN(30,0,1) = 14.5
QIWEN(30,1,1) = 29
QIWEN(31,0,1) = 15
QIWEN(31,1,1) = 29
QIWEN(32,0,1) = 15.5
QIWEN(32,1,1) = 29
QIWEN(33,0,1) = 16
QIWEN(33,1,1) = 29
QIWEN(34,0,1) = 16.5
QIWEN(34,1,1) = 29
QIWEN(35,0,1) = 17
QIWEN(35,1,1) = 29
QIWEN(36,0,1) = 17.5
QIWEN(36,1,1) = 29
QIWEN(37,0,1) = 18
QIWEN(37,1,1) = 29
QIWEN(38,0,1) = 18.5
QIWEN(38,1,1) = 29
QIWEN(39,0,1) = 19
QIWEN(39,1,1) = 29
QIWEN(40,0,1) = 19.5
QIWEN(40,1,1) = 29
QIWEN(41,0,1) = 20
QIWEN(41,1,1) = 29
QIWEN(42,0,1) = 20.5
QIWEN(42,1,1) = 29
QIWEN(43,0,1) = 21
QIWEN(43,1,1) = 29
QIWEN(44,0,1) = 21.5
QIWEN(44,1,1) = 29
QIWEN(45,0,1) = 22
QIWEN(45,1,1) = 29
QIWEN(46,0,1) = 22.5
QIWEN(46,1,1) = 29
QIWEN(47,0,1) = 23
QIWEN(47,1,1) = 29
QIWEN(48,0,1) = 23.5
QIWEN(48,1,1) = 29
QIWEN(49,0,1) = 24
QIWEN(49,1,1) = 29
QIWEN(50,0,1) = 24.5
QIWEN(50,1,1) = 29
QIWEN(51,0,1) = 25
QIWEN(51,1,1) = 29
QIWEN(52,0,1) = 25.5
QIWEN(52,1,1) = 29
QIWEN(53,0,1) = 26
QIWEN(53,1,1) = 29
QIWEN(54,0,1) = 26.5
QIWEN(54,1,1) = 29
QIWEN(55,0,1) = 27
QIWEN(55,1,1) = 29
QIWEN(56,0,1) = 27.5
QIWEN(56,1,1) = 29
QIWEN(57,0,1) = 28
QIWEN(57,1,1) = 29
  !输入热生成率函数
*SET,_FNCNAME,'heats'
*DIM,%_FNCNAME%,TABLE,6,16,1
   ! Begin of equation: 2450*0.82*280*0.13*exp(-0.82*{TIME})
%_FNCNAME%(0,0,1)= 0.0, -999
%_FNCNAME%(2,0,1)= 0.0
%_FNCNAME%(3,0,1)= 0.0
%_FNCNAME%(4,0,1)= 0.0
%_FNCNAME%(5,0,1)= 0.0
%_FNCNAME%(6,0,1)= 0.0
%_FNCNAME%(0,1,1)= 1.0, -1, 0, 2500, 0, 0, 0
%_FNCNAME%(0,2,1)= 0.0, -2, 0, 0.8, 0, 0, -1
%_FNCNAME%(0,3,1)=   1, -3, 0, 1, -1, 3, -2
%_FNCNAME%(0,4,1)= 0.0, -1, 0, 280, 0, 0, -3
%_FNCNAME%(0,5,1)= 0.0, -2, 0, 1, -3, 3, -1
%_FNCNAME%(0,6,1)= 0.0, -1, 0, 0.205, 0, 0, -2
%_FNCNAME%(0,7,1)= 0.0, -3, 0, 1, -2, 3, -1
%_FNCNAME%(0,8,1)= 0.0, -1, 0, 0, 0, 0, 0
%_FNCNAME%(0,9,1)= 0.0, -2, 0, 1, 0, 0, -1
%_FNCNAME%(0,10,1)= 0.0, -4, 0, 1, -1, 2, -2
%_FNCNAME%(0,11,1)= 0.0, -1, 0, 0.80, 0, 0, -4
%_FNCNAME%(0,12,1)= 0.0, -2, 0, 1, -4, 3, -1
%_FNCNAME%(0,13,1)= 0.0, -1, 0, 1, -2, 3, 1
%_FNCNAME%(0,14,1)= 0.0, -1, 7, 1, -1, 0, 0
%_FNCNAME%(0,15,1)= 0.0, -2, 0, 1, -3, 3, -1
%_FNCNAME%(0,16,1)= 0.0, 99, 0, 1, -2, 0, 0
   ! End of equation: 2450*0.7462*227.2246*0.13*exp(-0.7426*{TIME})
!创建几何体
BLC4,-14.0,-16,14.0,16,2.6          !创建混凝土块
BLOCK,-14.0,-5.5,-16,-11,-1.8,0
vadd,1,2
BLOCK,-14.0,10,-11,10,-5,0           !创建基础土体
BLOCK,-14.0,-5.5,-16,-11,-5,-1.8
BLOCK,-5.5,10,-16,-11,-5,0
vadd,2,4,1
vglue,all
NUMMRG,ALL                  !合并所有重复元素
NUMCMP, ALL                 !压缩所有元素的编号
CSYS,0                      !返回全局坐标系
      !进行网格划分
finish
/SOLU                       !进入求解器
ANTYPE,4                    !选择瞬态求解
TRNOPT,FULL
LUMPM,0
ESEL,S,MAT,,1               !选择混凝土体的所有结点
NSLE,S
IC,all,TEMP,32        !混凝土的浇筑温度为23.6
ESEL,S,MAT,,2               !选择基础土体的所有结点
NSLE,S
IC,all,TEMP,20             !基础的初始温度为16
ALLSEL
SFA,4,1,CONV,280, %QIWEN%  !四周木模对流系数616.32
SFA,5,1,CONV,280, %QIWEN%
SFA,9,1,CONV,280, %QIWEN%
SFA,11,1,CONV,280, %QIWEN%
SFA,2,1,CONV,600, %QIWEN%  !上面裸露对流系数616.32
BFV,1,HGEN, %HEATS%           !输入热生成率heats
ALLSE                         !选择所有
TRNOPT,FULL                   !设置计算方法
*DO,DAY,0.5,28,0.5            !设置循环计算
TIME,DAY                      !设置荷载步时间
AUTOTS,0                      !关闭自动时间步长
KBC,0                         !设置阶梯荷载步
TSRES,ERASE                   !Defines an array of keytimes at which the time-stepping strategy changes
OUTRES,ALL,ALL                !输出所有项
SOLVE                         !开始计算
*ENDDO                        !终止循环计算
/post1
plnsol,temp
set,20
/replot
!结构应力分析
/PREP7                                !前处理
ETCHG,TTS                             !转换热分析单元为结构单元
  !输入参数
!定义变化弹模EXX
*DIM,EXX,ARRAY,30
EXX(1,1,1) = 0.304e10
EXX(2,1,1) = 0.608e10
EXX(3,1,1) = 1.216e10
EXX(4,1,1) = 1.824e10
EXX(5,1,1) = 2.432e10
EXX(6,1,1) = 3.04e10
EXX(7,1,1) = 3.144e10
EXX(8,1,1) = 3.248e10
EXX(9,1,1) = 3.352e10
EXX(10,1,1) = 3.456e10
EXX(11,1,1) = 3.506e10
EXX(12,1,1) = 3.556e10
EXX(13,1,1) = 3.606e10
EXX(14,1,1) = 3.656e10
EXX(15,1,1) = 3.663e10
EXX(16,1,1) = 3.67e10
EXX(17,1,1) = 3.677e10
EXX(18,1,1) = 3.684e10
EXX(19,1,1) = 3.691e10
EXX(20,1,1) = 3.702e10
EXX(21,1,1) = 3.709e10
EXX(22,1,1) = 3.716e10
EXX(23,1,1) = 3.723e10
EXX(24,1,1) = 3.73e10
EXX(25,1,1) = 3.737e10
EXX(26,1,1) = 3.743e10
EXX(27,1,1) = 3.75e10
EXX(28,1,1) = 3.757e10
EXX(29,1,1) = 3.759e10
EXX(30,1,1) = 3.760e10
!定义30种材料每0.5d一种材料来反映弹模的改变
*DO,I,1,30,1
    MP,DENS,I,2500       !混凝土 密度为2500
    MP,EX,I,EXX(I)        !混凝土 弹模为EXX(I)
    MP,PRXY,I,0.167       !混凝土 泊松比为0.167
    MP,ALPX,I,0.75E-5     !混凝土 热膨胀系数为0.8e-5
    MP,REFT,I,15          !定义参考温度
*ENDDO
VCLEAR, 2, 2, 1           !清除基础土体网格
VDELE, 2, 2, 1, 1         !删除基础土体
ALLSEL                    !选择选择所有
/SOLU                     !进入求解器
NROPT,FULL                !Specifies the Newton-Raphson options in a full transient analysis
NLGEOM,ON                 !考虑大变形的影响
ASEL,S,,,1,1,1            !选择面1
NSLA,S,1                  !选择面1上的结点
D,all,ALL                 !加基础全约束
ALLSEL                    !选择选择所有
DA,3,SYMM                 !加对称约束
DA,6,SYMM                 !加对称约束
DA,4,SYMM                 !加对称约束
DA,5,SYMM
DA,9,SYMM                 !加对称约束
DA,11,SYMM
DA,12,SYMM                 !加对称约束
DA,13,SYMM
DA,14,SYMM                 !加对称约束
DA,15,SYMM
ALLSEL
I=1
*DO,DAY,0.5,10,0.5
    ESEL, S, MAT, , I, I,1                    !选择混凝土材料号为I的元素
    ACEL,0,0,-9.8,                            !GRAVITY LOAD 施加重力荷载加速度
    LDREAD,TEMP,,,DAY, ,'themal','rth',' '    !TEMP LOAD Reads results from the results file and applies them as loads.
    TIME,DAY
    AUTOTS,0
    KBC,0                                     !设置阶梯荷载步
    OUTRES,ALL,ALL,                           !输出所有的结果
    SOLVE                                     !计算
    I=I+1
    *IF,I,LE,20,THEN
        MPCHG,I,ALL
    *ENDIF
*ENDDO
发表于 2005-6-16 20:02:58 | 显示全部楼层 来自 大连理工大学
Re:温度和应力偶合场 的问题,请教!!先谢了!
ANSYS是不能做时变材料的应力分析的,按上述方法计算混凝土的应力场只能得到压应力的结果。
建议你采用能够考虑时变材料的有限元分析软件进行混凝土温度应力场分析。
例如ABAQUS软件 ,它可以考虑混凝土的时变性,即弹性模量随时间变化。
 楼主| 发表于 2005-7-6 09:17:31 | 显示全部楼层 来自 黑龙江哈尔滨
可以做出来一部分是压应力,另外一部分是拉应力,不过是压应力占很大的比例!
发表于 2005-7-7 10:29:52 | 显示全部楼层 来自 湖南长沙
楼主,ansys是不能做早龄期混凝土的热--应力分析的,这个我们已经证明了。
二楼的,我也看过abaqus的一些资料,了解了一下abaqus,怎么没有发现可以定义弹模和时间的曲线呢?
如果真的能做,那太好了
能给我们详细介绍一下吗?
落魄书生 该用户已被删除
发表于 2005-7-8 15:41:21 | 显示全部楼层 来自 江苏南京
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2024-9-22 11:26 , Processed in 0.057981 second(s), 15 queries , Gzip On, MemCache On.
