查看: 1106|回复: 19
【原创】热电耦合- 通电金属桥的温升
发表于 2005-9-9 00:28:13 | 显示全部楼层 |阅读模式 来自 美国
在这个例子中, 电流通过suspended金属桥,Joule heating引起温升,并伴随相变。例子很简单,只是说明如何做热电耦合。
FINISH
/CLEAR
k=95
DEN=3900
Cp=450
/PREP7
um=1e-6
L=100*um
W=10*um
T=0.05*um
mA=0.001
rou=1e-7
I=3.1624*mA
DT=5
FUSION=15*Cp
T0=480
T_MELT=500
T_LOW=0
T_HIGH=1.5*T_MELT
Size=1*um
ET,1,SOLID69
UIMP,1,DENS, , ,DEN,
UIMP,1,KXX,KYY,KZZ,k,k,k,
UIMP,1,RSVX,RSVY,RSVZ,rou,rou,rou
!UIMP,1,C, , ,Cp,
MPTEMP,1,T_LOW,T_MELT-DT/2,T_MELT+DT/2,T_HIGH
MPDATA,ENTH,1,1,0,DEN*Cp*(T_MELT-DT/2-T_LOW),DEN*(Cp*(T_MELT-DT/2-T_LOW)+FUSION),DEN*(Cp*(T_MELT-DT/2-T_LOW)+FUSION+Cp*(T_HIGH-T_MELT-DT/2))
BLC4, 0, 0, W, L, T
lsel,s,LOC,x,0,0
lsel,r,LOC,y,0,L
lesize,all,Size,
allsel,all
lsel,s,LOC,y,0,0
lsel,r,LOC,x,0,W
lesize,all,W,
allsel,all
TYPE,1
MAT,1
mshkey,1
mshape,0,3d
vmesh,1
/solu
tunif,T0
TREF,T0
asel,s,LOC,y,0,0
asel,a,LOC,y,L,L
DA,all,TEMP,T0   !Two ends of the bridge are kept at T0
allsel,all
asel,s,LOC,y,0,0  ! Assume one end V=0
DA,ALL,VOLT,0
asel,all
nsel,s,LOC,y,L,L
cp,2,volt,all        ! Couple VOLT dofs
ni=ndnext(0)         ! Get master node
nsel,all
VSEL,ALL
f,ni,amps,I      !Apply current at one end
allsel,all
ANTYPE,4
SOLCONTROL,OM,0
TIME,1e-4
AUTOTS,-1
DELTIM,1e-6, , ,1
KBC,1
OUTRES,ALL,ALL,
SOLVE
发表于 2005-9-9 09:23:26 | 显示全部楼层 来自 陕西西安
Re:【原创】热电耦合- 通电金属桥的温升
学习学习先!
发表于 2007-1-31 18:43:44 | 显示全部楼层 来自 辽宁沈阳
MPTEMP,1,T_LOW,T_MELT-DT/2,T_MELT+DT/2,T_HIGH  !dt=5??这里是怎么设置的4点??
MPDATA,ENTH,1,1,0,DEN*Cp*(T_MELT-DT/2-T_LOW),DEN*(Cp*(T_MELT-DT/2-T_LOW)+FUSION),DEN*(Cp*(T_MELT-DT/2-T_LOW)+FUSION+Cp*(T_HIGH-T_MELT-DT/2))!FUSION=15*Cp是什么?为什么要加上?
 楼主| 发表于 2007-2-4 11:56:46 | 显示全部楼层 来自 美国
The below code is to mimic the phase change, e.g. the fusion heat when the solid become liquid.
When fusion happenes, the material absorbs the heat but the temperature doesn't increase until it becomes liquid. This is physically equivalent to the case that material has infinite heat capacity at melting point. I set a small temperature dt around the melting point: T_MELT,   let dt*Cp =   fusion heat.
原帖由 ilovemm 于 2007-1-31 18:43 发表
MPDATA,ENTH,1,1,0,DEN*Cp*(T_MELT-DT/2-T_LOW),DEN*(Cp*(T_MELT-DT/2-T_LOW)+FUSION),DEN*(Cp*(T_MELT-DT/2- ...
发表于 2007-3-25 14:02:08 | 显示全部楼层 来自 黑龙江哈尔滨
谢谢了.正愁找不到这方面的例子呢.
发表于 2007-3-27 09:59:23 | 显示全部楼层 来自 合肥工业大学
顶,好东西
发表于 2009-12-14 14:34:39 | 显示全部楼层 来自 北京大兴
谢谢楼主的例子
发表于 2009-12-19 22:54:07 | 显示全部楼层 来自 上海
好贴,要顶啊!正在学习中!
发表于 2010-3-16 14:28:18 | 显示全部楼层 来自 上海
多谢。学习先
发表于 2010-3-27 21:33:55 | 显示全部楼层 来自 江西南昌
我现在做的东西也是由电产生焦耳热,初学者看不懂你写的啊,能说的具体些吗?
发表于 2010-5-17 23:15:27 | 显示全部楼层 来自 广东深圳
好东西,正在学习,谢谢楼主
发表于 2011-10-8 20:30:37 | 显示全部楼层 来自 上海
好,支持
发表于 2011-11-23 19:50:02 | 显示全部楼层 来自 北京
好东西正要学习一下,多谢!!
请问KXX,和RSVX这两个参数是不是一定要把三个方向都定义了才可以正常计算?
发表于 2011-11-25 21:39:46 | 显示全部楼层 来自 湖北武汉
好东东就大家分享啊
发表于 2011-12-14 19:02:50 | 显示全部楼层 来自 江苏南京
我现在做的东西
发表于 2012-3-21 20:56:43 | 显示全部楼层 来自 贵州贵阳
好东西,多谢楼主!
发表于 2012-5-16 21:47:43 | 显示全部楼层 来自 江西
好东西  先学习
发表于 2012-8-9 14:51:04 | 显示全部楼层 来自 广东佛山
新手上路,顶上!
发表于 2013-1-15 13:16:13 | 显示全部楼层 来自 河南许昌
温升带相变的例子,急需
发表于 2015-8-10 15:18:44 | 显示全部楼层 来自 江苏南京
why is 2? not 1
GMT+8, 2024-9-29 03:20 , Processed in 0.086218 second(s), 17 queries , Gzip On, MemCache On.
