查看: 149|回复: 1
请问流场求解时出现的错误地解决方法
发表于 2005-10-9 14:35:14 | 显示全部楼层 |阅读模式 来自 江苏镇江
流场中计算时出现以下的错误
*** ERROR ***                           CP=    155.063   TIME= 11:49:55
Negative or zero temperatures may be avoided by either mesh refinement
or modified inertial relaxation especially if Petrov-Galerkin
formulation is used for the energy equation(FLDA,ENRG,SUPG,T).
*** ERROR ***                           CP=    155.183   TIME= 11:49:58
Negative or zero temperature detected.  This may be caused by a
diverging solution or by an incorrect temperature or property value.
A temperature offset may also be required.  (TOFFST)
  Node = 771.
请问有什么好的解决方法吗
发表于 2010-1-23 17:17:19 | 显示全部楼层 来自 安徽合肥
楼主您好,我也遇到了这种错误,请问你解决了吗,怎么解决的呢,指点一下啊,谢谢,急用
GMT+8, 2024-9-20 21:38 , Processed in 0.027613 second(s), 10 queries , Gzip On, MemCache On.
