查看: 194|回复: 0
[2. C/C++/C#] 请教高手:SparseLib++ 解稀疏矩阵方程的一个问题
发表于 2005-11-4 20:41:45 | 显示全部楼层 |阅读模式 来自 中国农业大学
在网上看到了这样的例子(附后),下载了SparseLib++ 1.6版,但是编译下面的文件的时候提示:“COMPLEX没有定义”。编译器不认识COMPLEX这个结构(或类)。找遍了spareselib的所有头文件,没找到COMPLEX定义的地方;在VC的include目录下面也没找到。因此,我怀疑用VC在Windows2000下面是不是不能编译这个文件?这个SparseLIb++是不是用于linux的?
请用过的朋友指点一二。
另外:这个软件包运行的速度怎样?
#include <cstdlib>
#include <iostream>
#include "compcol_double.h"
#include "mvvtp.h"
#include "mvblasd.h"
#include "ilupre_double.h"
#include "gmres.h"
#include "spblas.h"
#include "mvm.h"
//#include MATRIX_H
//using namespace std;
int main(void)
  double val[] = {10, 3, 3, 9, 7, 8, 4, 9, 8, 7, 7, 9, -2, 5, 9, 2, 3, 13, -1};
  int row_ind[] = {0, 1, 3, 1, 2, 4, 5, 2, 3, 2, 3, 4,  0, 3, 4, 5, 1, 4,  5};
  int col_ptr[] = {0, 3, 7, 9, 12, 16, 19};
  int maxit = 150;                     // maximum iteration
  int nUnknown = 6;                    // unknown, the size of Jacobi
  int nNonZero = 19;                   // nonZero values in the matrix
  int results;
  int restart = 10;                    // restart iterations
  double tol = 1.e-6;                  // convergence tolerance
  CompCol_Mat_double  Jacobi(nUnknown, nUnknown, nNonZero, val, row_ind, col_ptr);
  //cout << Jacobi;
  CompCol_ILUPreconditioner_double M(Jacobi); // construct preconditioner
  MATRIX_double H(restart+1, restart, 0.0);   // storage for upper Hessenberg H;
  VECTOR_double xi(nUnknown, 0);
  VECTOR_double rhs(nUnknown);
  for(int i=0; i<nUnknown; i++)     rhs(i) =i+1;
*      maxit AND tol WILL BE CHANGED AFTER ONE CALL OF GMRES,        **
*      SO FOR NEXT CALL, YOU SHOULD RESTORE THE OLD VALUE OF THEM    **
  results = GMRES(Jacobi, xi, rhs, M, H, restart, maxit, tol); // call solver
  cout << "GMRES flag = " << results << endl;
  cout << "Iterations performed: " << maxit << endl;
  cout << "Tolerance achieved :" << tol << endl;
  for (i = 0; i < nUnknown; i ++){
    cout <<"xi["<<i<<"]="<<xi<<"\n";
  return results;
GMT+8, 2024-11-1 23:26 , Processed in 0.044031 second(s), 13 queries , Gzip On, MemCache On.
