- 2004-7-21
我在用UMAT计算过程中,算到中途就碰到这样的问题:在MSG、DAT和STA文件中都没有看到什么错误,但是计算却停止了,只在LOG文件中有这样一段话,请大侠们帮我分析一下。
ABAQUS Error: The executable D:\abaqus\6.5-1\exec\standard.exe
aborted with system error "拒绝访问。
" (error code 5).
Please check the .dat, .msg, and .sta files for error messages if the files
exist. If there are no error messages and you cannot resolve the problem,
please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run ABAQUS that you used when the problem occurred. Please contact your local ABAQUS support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
ABAQUS/Analysis exited with errors
Socket error: (10061, 'Connection refused') |
