- 1
- 2006-4-8
楼主 |
发表于 2006-8-1 16:14:31
来自 湖北武汉
首先谢谢andyxin的指点,我现在已经将柔性体装配到刚性体上,在加约束时老弹出如下错误,我不知道是什么原因造成的,希望你能指点我一下,
WARNING: Model .model_1 is no longer compatible with the ADAMS/Solver (FORTRAN).
.model_1.JOINT_121 is causing the incompatibility because:
1) Objects of type Cylindrical Joint are not compatible with the
2) The topology of the model has changed so .model_1.JOINT_121
is no longer connected in a way that is compatible with the
3) An attribute of .model_1.JOINT_121 is no longer compatible with
If you intend to use the ADAMS/Solver (FORTRAN), then be sure that you
set your preferences so ADAMS/Solver (FORTRAN) is the default as follows:
- From the Settings menu, point to Solver and select either
Solver Executable or Preferences, depending on the product
you are using.
- Press F1 in the dialog box that appears to learn more.
If you do not want to use the ADAMS/Solver (FORTRAN), you must change
your model to eliminate the incompatibilty. See the online help
for the object listed for more information. |
