- 2005-10-26
Input file: gear.k
The native file format : 32-bit small endian
Memory size from default : 8500000
expanding memory to 8500000
******** notice ******** notice ******** notice ********
* This is the LS-DYNA Explicit Finite Element code. *
* the validity, accuracy, or applicability of any results *
* obtained from this system. The user must verify his own *
* results. *
* LSTC endeavors to make the LS-DYNA code as complete, *
* accurate and easy to use as possible. *
* Suggestions and comments are welcomed. Please report any *
* errors encountered in either the documentation or results *
* immediately to LSTC through your site focus. *
* Copyright (C) 1990-2003 *
* by Livermore Software Technology Corp. (LSTC) *
* All rights reserved *
contracting memory to 56624
expanding memory to 93248
expanding memory to 159782
expanding memory to 351590
expanding memory to 381590
expanding memory to 441590
expanding memory to 472608
expanding memory to 534108
expanding memory to 556126
expanding memory to 576126
expanding memory to 687117
expanding memory to 707295
expanding memory to 864192
contracting memory to 2
LS-DYNA will perform a structural only analysis
LS-DYNA user input
ls-dyna (version 970 ) date 07/30/2004
expanding memory to 2387
expanding memory to 9981
expanding memory to 102279
expanding memory to 409478
expanding memory to 417614
expanding memory to 418032
expanding memory to 637685
expanding memory to 639691
expanding memory to 642139
expanding memory to 645425
expanding memory to 739887
contracting memory to 719709
expanding memory to 815224
expanding memory to 970935
expanding memory to 1001383
contracting memory to 971533
expanding memory to 971563
contracting memory to 971563
expanding memory to 971643
contracting memory to 971643
expanding memory to 971645
contracting memory to 971645
1 t 0.0000E+00 dt 9.30E-04 flush i/o buffers
1 t 0.0000E+00 dt 9.30E-04 write ANSYS result file
2 t 9.3039E-04 dt 8.45E-04 write ANSYS result file
3 t 1.7758E-03 dt 7.61E-04 write ANSYS result file
4 t 2.5369E-03 dt 6.04E-04 write ANSYS result file
5 t 3.1413E-03 dt 4.84E-04 write ANSYS result file
6 t 3.6257E-03 dt 3.87E-04 write ANSYS result file
7 t 4.0132E-03 dt 3.10E-04 write ANSYS result file
8 t 4.3234E-03 dt 2.46E-04 write ANSYS result file
9 t 4.5696E-03 dt 1.94E-04 write ANSYS result file
10 t 4.7639E-03 dt 1.53E-04 write ANSYS result file
11 t 4.9164E-03 dt 1.19E-04 write ANSYS result file
12 t 5.0358E-03 dt 9.31E-05 write ANSYS result file
13 t 5.1289E-03 dt 7.25E-05 write ANSYS result file
14 t 5.2013E-03 dt 5.64E-05 write ANSYS result file
15 t 5.2577E-03 dt 4.38E-05 write ANSYS result file
16 t 5.3016E-03 dt 3.41E-05 write ANSYS result file
17 t 5.3357E-03 dt 2.65E-05 write ANSYS result file
18 t 5.3622E-03 dt 2.07E-05 write ANSYS result file
19 t 5.3829E-03 dt 1.62E-05 write ANSYS result file
20 t 5.3990E-03 dt 1.26E-05 write ANSYS result file
21 t 5.4116E-03 dt 9.88E-06 write ANSYS result file
22 t 5.4215E-03 dt 7.74E-06 write ANSYS result file
23 t 5.4292E-03 dt 6.10E-06 write ANSYS result file
24 t 5.4353E-03 dt 4.84E-06 write ANSYS result file
25 t 5.4402E-03 dt 3.86E-06 write ANSYS result file
26 t 5.4440E-03 dt 3.01E-06 write ANSYS result file
27 t 5.4470E-03 dt 2.27E-06 write ANSYS result file
28 t 5.4493E-03 dt 1.76E-06 write ANSYS result file
29 t 5.4511E-03 dt 1.48E-06 write ANSYS result file
30 t 5.4525E-03 dt 1.17E-06 write ANSYS result file
31 t 5.4537E-03 dt 9.35E-07 write ANSYS result file
32 t 5.4547E-03 dt 8.49E-07 write ANSYS result file
33 t 5.4555E-03 dt 6.62E-07 write ANSYS result file
34 t 5.4562E-03 dt 5.41E-07 write ANSYS result file
35 t 5.4567E-03 dt 4.41E-07 write ANSYS result file
36 t 5.4571E-03 dt 1.52E-07 write ANSYS result file
37 t 5.4573E-03 dt 1.67E-07 write ANSYS result file
38 t 5.4575E-03 dt 1.84E-07 write ANSYS result file
39 t 5.4576E-03 dt 1.80E-07 write ANSYS result file
40 t 5.4578E-03 dt 1.73E-07 write ANSYS result file
41 t 5.4580E-03 dt 1.90E-07 write ANSYS result file
42 t 5.4582E-03 dt 1.00E-07 write ANSYS result file
*** Error negative volume in brick element # 7333 cycle 42
******** minimum time step size reached *********
On a restart minimum timestep will be 0.000E+00
42 t 5.4583E-03 dt-1.88E-07 write ANSYS result file
E r r o r t e r m i n a t i o n
Memory required for explicit solution : 1024447
Additional dynamically allocated memory: 25220
Total: 1049667
T i m i n g i n f o r m a t i o n
CPU(seconds) %CPU Clock(seconds) %Clock
Initialization ....... 9.0000E+00 47.37 8.9690E+00 47.79
Element processing ... 1.0000E+00 5.26 2.6420E+00 14.08
Binary databases ..... 9.0000E+00 47.37 7.0760E+00 37.71
ASCII database ....... 0.0000E+00 0.00 1.6000E-02 0.09
Contact algorithm .... 0.0000E+00 0.00 4.7000E-02 0.25
Contact entities ..... 0.0000E+00 0.00 0.0000E+00 0.00
Rigid bodies ......... 0.0000E+00 0.00 1.6000E-02 0.09
Implicit Nonlinear ... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Lin. Alg. ... 0.0000E+00 0.00 0.0000E+00 0.00
T o t a l s 1.9000E+01 100.00 1.8766E+01 100.00
Problem time = 5.4583E-03
Problem cycle = 42
Total CPU time = 19 seconds ( 0 hours 0 minutes 19 seconds)
CPU time per zone cycle = 29192 nanoseconds
Clock time per zone cycle= 28600 nanoseconds
Number of CPU's 1
NLQ used/max 96/ 96
Start time 11/26/2006 14:40:03
End time 11/26/2006 14:40:23
Elapsed time 20 seconds ( 0 hours 0 minutes 20 seconds)
大人们怎么办? |
