- 4
- 2004-10-6
97单元keyopt=0~4,分别代表不同的类型
KEYOPT(1) Element degrees of freedom and formulation selection:
Classical Formulation
0 -- AX, AY, AZ degrees of freedom: static domain, source domain !静场
1 -- AX, AY, AZ, VOLT degrees of freedom: eddy current domain, velocity effect domain !计算涡流,velocity effect 怎么用呀?需要耦合电压自由度
2 -- AX, AY, AZ, CURR degrees of freedom: voltage-fed stranded coil !能不能这样理解,加载电压的绞线圈,需要耦合电流自由度?
For voltage forced magnetic field (KEYOPT(1) = 2) and circuit coupled problems (KEYOPT(1) = 3,4), note the following additional restrictions:
For (KEYOPT(1) = 2 or 3), all CURR degrees of freedom in a coil region must be coupled , and all EMF degrees of freedom in a coil region must be coupled.!是不是意味着这个类型必须耦合CURR自由度和EMF自由度?
3 -- AX, AY, AZ, CURR, EMF degrees of freedom: circuit-coupled stranded coil !能不能这样理解需耦合CURR自由度和EMF自由度,并加载电流/电流密度载荷?
4 -- AX, AY, AZ, VOLT, CURR degrees of freedom: circuit-coupled massive conductor !块导体,需耦合volt和CURR自由度么?并加载电流,这个电流是不是总电流=匝数*每匝电流,还是加载每匝电流?
另一个问题:绞线圈实常数的问题
| | | | VOLU | This represents the actual volume of the finite element coil region, not the total volume of the full coil. !线圈一般是圆环柱,那么圆环柱内部的区域算是the finite element coil region,因此也应算到这个体积里面吧? | |
| CSYM | This constant is the coil symmetry factor; the multiplier of the VOLU constant required to represent the total volume of the full coil. CSYM times VOLU equals the total volume of the conductor.
!CSYM=线圈实际体积/VOLU
| FILL | The coil fill factor represents the fraction of the coil cross-section that the conductor occupies. You can use this factor to adjust coil resistance. !我做的变压器模型,因为一次二次耦合124 绞线圈单元,结果显示一次侧输入(入口)电阻太大,导致(我也不知道是不是有因果关系)二次侧感应出来的电压很小很小,因此二次侧电流和一次侧电流很小,各个参数差不多小了4个等级,我不知道是哪个地方出了问题 |
对变压器仿真有兴趣的朋友请进http://www.simwe.com/forum/thread-769523-2-10.html,帮我提提意见,谢了
[ 本帖最后由 ponderadams 于 2007-5-23 10:02 编辑 ] |
