查看: 394|回复: 7
[入门&进阶] 给大家发一些多学科设计优化方面的词条解释 (From Wikipedia)
发表于 2007-11-13 18:47:19 | 显示全部楼层 |阅读模式 来自 德国
Multidisciplinary design optimizationFrom Wikipedia, the free encyclopedia
Jump to: navigation, search
Multidisciplinary design optimization (MDO) is a field of engineering that uses optimization methods to solve design problems incorporating a number of disciplines. It is also known as multidisciplinary optimization and multidisciplinary system design optimization (MSDO).
MDO allows designers to incorporate all relevant disciplines simultaneously. The optimum of the simultaneous problem is superior to the design found by optimizing each discipline sequentially, since it can exploit the interactions between the disciplines. However, including all disciplines simultaneously significantly increases the complexity of the problem.
These techniques have been used in a number of fields, including automobile design, naval architecture, electronics, computers, and electricity distribution. However, the largest number of applications have been in the field of aerospace engineering, such as aircraft and spacecraft design. For example, the proposed Boeing blended wing body (BWB) aircraft concept has used MDO extensively in the conceptual and preliminary design stages. The disciplines considered in the BWB design are aerodynamics, structural analysis, propulsion, control theory, and economics.
Contents[hide]
[edit] HistoryTraditional engineering design has normally been performed by teams, each with expertise in a specific discipline, such as aerodynamics or structures. Each team would use its members experience and judgement to develop a workable design, usually sequentially. For example, the aerodynamics experts would outline the shape of the body, and the structural experts would be expected to fit their design within the shape specified. The goals of the teams were generally performance-related, such as maximum speed, minimum drag, or minimum structural weight.
Between 1970 and 1990, two major developments in the aircraft industry changed the approach of aircraft design engineers to their design problems. The first was computer-aided design, which allowed designers to quickly modify and analyse their designs. The second was changes in the procurement policy of most airlines and military organizations, particularly the military of the United States, from a performance-centred approach to one that emphasized lifecycle cost issues. This led to an increased concentration on economic factors and the attributes known as the "ilities": manufacturability, reliability, maintainability, etc.
Since 1990, the techniques have expanded to other industries. Globalization has resulted in more distributed, decentralized design teams. The high-performance personal computer has largely replaced the centralized supercomputer and the Internet and local area networks have facilitated sharing of design information. Disciplinary design software in many disciplines (such as NASTRAN, a finite element analysis program for structural design) have become very mature. In addition, many optimization algorithms, in particular the population-based algorithms, have advanced significantly.
[edit] Origins in structural optimizationWhereas optimization methods are nearly as old as calculus, dating back to Isaac Newton, Leonhard Euler, Daniel Bernoulli, and Joseph Louis Lagrange, who used them to solve problems such as the shape of the catenary curve, numerical optimization reached prominence in the digital age. Its systematic application to structural design dates to its advocacy by Schmit in 1960. The success of structural optimization in the 1970s motivated the emergence of multidisciplinary design optimization (MDO) in the 1980’s. Jaroslaw Sobieski championed decomposition methods specifically designed for MDO applications. The following synopsis focuses on optimization methods for MDO. First, the popular gradient-based methods used by the early structural optimization and MDO community are reviewed. Then those methods developed in the last dozen years are summarized.
[edit] Gradient-based methodsThere were two schools of structural optimization practitioners using gradient-based methods during the 1960s and 1970s: optimality criteria and mathematical programming. The optimality criteria school derived recursive formulas based on the Karesh-Kuhn-Tucker (KKT) necessary conditions for an optimal design. The KKT conditions were applied to classes of structural problems such as minimum weight design with constraints on stresses, displacements, buckling, or frequencies [Rozvany, Berke, Venkayya, Khot, et al.] to derive resizing expressions particular to each class. The mathematical programming school employed classical gradient-based methods to structural optimization problems. The method of usable feasible directions, Rosen’s gradient projection (generalized reduce gradient) method, sequential unconstrained minimization techniques, sequential linear programming and eventually sequential quadratic programming methods were common choices. Schittkowski et al. reviewed the methods current by the early 1990s.
The gradient methods unique to the MDO community derive from the combination of optimality criteria with math programming, first recognized in the seminal work of Fleury and Schmit who constructed a framework of approximation concepts for structural optimization. They recognized that optimality criteria were so successful for stress and displacement constraints, because that approach amounted to solving the dual problem for Lagrange multipliers using linear Taylor series approximations in the reciprocal design space. In combination with other techniques to improve efficiency, such as constraint deletion, regionalization, and design variable linking, they succeeded in uniting the work of both schools. This approximation concepts based approach forms the basis of the optimization modules in modern structural design software [ASTROS, MSC.Nastran, Genesis, I-DEAS, iSight].
Approximations for structural optimization were initiated by the reciprocal approximation [Schmit and Miura] for stress and displacement response functions. Other intermediate variables were employed for plates. Combining linear and reciprocal variables, Starnes and Haftka developed a conservative approximation to improve buckling approximations. Fadel chose an appropriate intermediate design variable for each function based on a gradient matching condition for the previous point. Vanderplaats initiated a second generation of high quality approximations when he developed the force approximation as an intermediate response approximation to improve the approximation of stress constraints. Canfield developed a Rayleigh Quotient approximation to improve the accuracy of eigenvalue approximations. Barthelemey and Haftka published a comprehensive review of approximations in 1993.
[edit] Non-gradient-based methods
[edit] Recent MDO methodsMDO practitioners have investigated optimization methods in several broad areas in the last dozen years. These include decomposition methods, approximation methods, evolutionary algorithms, response surface methodologies, reliability-based optimization, and multiobjective optimization approaches.
The exploration of decomposition methods has continued in the last dozen years with the development and comparison of a number of approaches, classified variously as hierarchic and non-hierarchic, or collaborative and non-collaborative. Approximation methods spanned a diverse set of approaches, including the development of approximations for surrogate models, variable fidelity models, and trust region management strategies. The development of multipoint approximations burred the distinction with response surface methods. Kriging methods became popular.
Response surface methodology, developed extensively by the operations research community, received much attention in the MDO community in the last dozen years. A driving force for their use has been the development of massively parallel systems for high performance computing, which are naturally suited to distributing the function evaluations from multiple disciplines that are required for the construction of response surfaces. Distributed processing is particularly suited to the design process of complex systems in which analysis of different disciplines may be accomplished naturally on different computing platforms and even by different teams.
Evolutionary methods led the way in the exploration of non-gradient methods for MDO applications. They also have benefited from the availability of massively parallel high performance computers, since they inherently require many more function evaluations than gradient-based methods. Their primary benefit lies in their ability to handle discrete design variables and the potential to find globally optimal solutions.
Reliability-based optimization (RBO) is a growing area of interest in MDO. Like response surface methods and evolutionary algorithms, RBO benefits from parallel computation, because the numeric integration to calculate the probability of failure requires many function evaluations. One of the first approaches employed approximation concepts to integrate the probability of failure. The classical first-order reliability method (FORM) and second-order reliability method (SORM) are still popular. Grandhi used appropriate normalized variables about the most probable point of failure, found by a two-point adaptive nonlinear approximation to improve the accuracy and efficiency. Southwest Research Institute has figured prominently in the development of RBO, implementing state-of-the-art reliability methods in commercial software. RBO has reached sufficient maturity to appear in commercial structural analysis programs like MSC.Nastran.
[edit] Problem formulationProblem formulation is normally the most difficult part of the process. It is the selection of design variables, constraints, objectives, and models of the disciplines. A further consideration is the strength and breadth of the interdisciplinary coupling in the problem.
[edit] Design variablesA design variable is a specification that is controllable from the point of view of the designer. For instance, the thickness of a structural member can be considered a design variable. Another might be the material the member is made out of. Design variables can be continuous (such as a wing span), discrete (such as the number of ribs in a wing), or boolean (such as whether to build a monoplane or a biplane). Design problems with continuous variables are normally solved more easily.
Design variables are often bounded, that is, they often have maximum and minimum values. Depending on the solution method, these bounds can be treated as constraints or separately.
[edit] ConstraintsA constraint is a condition that must be satisfied in order for the design to be feasible. An example of a constraint in aircraft design is that the lift generated by a wing must be equal to the weight of the aircraft. In addition to physical laws, constraints can reflect resource limitations, user requirements, or bounds on the validity of the analysis models. Constraints can be used explicitly by the solution algorithm or can be incorporated into the objective using Lagrange multipliers.
[edit] ObjectivesAn objective is a numerical value that is to be maximized or minimized. For example, a designer may wish to maximize profit or minimize weight. Many solution methods work only with single objectives. When using these methods, the designer normally weights the various objectives and sums them to form a single objective. Other methods allow multiobjective optimization, such as the calculation of a Pareto front.
[edit] ModelsThe designer must also choose models to relate the constraints and the objectives to the design variables. These models are dependent on the discipline involved. They may be empirical models, such as a regression analysis of aircraft prices, theoretical models, such as from computational fluid dynamics, or reduced-order models of either of these. In choosing the models the designer must trade off fidelity with analysis time.
The multidisciplinary nature of most design problems complicates model choice and implementation. Often several iterations are necessary between the disciplines in order to find the values of the objectives and constraints. As an example, the aerodynamic loads on a wing affect the structural deformation of the wing. The structural deformation in turn changes the shape of the wing and the aerodynamic loads. Therefore, in analysing a wing, the aerodynamic and structural analyses must be run a number of times in turn until the loads and deformation converge.
[edit] Standard formOnce the design variables, constraints, objectives, and the relationships between them have been chosen, the problem can be expressed in the following form:
find
that minimizes
subject to
and
where J is an objective,
is a vector of design variables,
is a vector of inequality constraints,
is a vector of equality constraints, and
and
are vectors of lower and upper bounds on the design variables. Maximization problems can be converted to minimization problems by multiplying the objective by -1. Constraints can be reversed in a similar manner. Equality constraints can be replaced by two inequality constraints.
[edit] Problem solutionThe problem is normally solved using appropriate techniques from the field of optimization. These include gradient-based algorithms, population-based algorithms, or others. Very simple problems can sometimes be expressed linearly; in that case the techniques of linear programming are applicable.
[edit] Population-based methods
[edit] Other methodsMost of these techniques require large numbers of evaluations of the objectives and the constraints. The disciplinary models are often very complex and can take significant amounts of time for a single evaluation. The solution can therefore be extremely time-consuming. Many of the optimization techniques are adaptable to parallel computing. Much current research is focused on methods of decreasing the required time.
Also, no existing solution method is guaranteed to find the global optimum of a general problem. Gradient-based methods find local optima with high reliability but are normally unable to escape a local optimum. Stochastic methods, like simulated annealing and genetic algorithms, will find a good solution with high probability, but very little can be said about the mathematical properties of the solution. It is not guaranteed to even be a local optimum. These methods often find a different design each time they are run.
[edit] ReferencesEarly examples of design optimization can be found in
  • Avriel, M., Rijckaert, M.J. and Wilde, D.J. (eds.), Optimization and Design, Prentice-Hall, 1973.
  • Avriel, M. and Dembo, R.S. (eds.), Mathematical Programming Studies on Engineering Optimization, North-Holland, 1979.
  • Siddall, J.N., Optimal Engineering Design, CRC, 1982.
Retrieved from "http://en.wikipedia.org/wiki/Multidisciplinary_design_optimization"
[ 本帖最后由 shehp 于 2007-11-13 19:24 编辑 ]
发表于 2007-12-7 10:30:37 | 显示全部楼层 来自 北京
xiexie
发表于 2008-8-1 17:29:14 | 显示全部楼层 来自 北京
thanks for your resource!
发表于 2009-6-21 10:38:52 | 显示全部楼层 来自 北京
Thank you very much!
发表于 2009-6-26 15:30:56 | 显示全部楼层 来自 陕西西安
谢谢楼主的分享!
发表于 2009-6-27 09:49:57 | 显示全部楼层 来自 北京
翻译一下萨。。
发表于 2009-6-29 11:10:22 | 显示全部楼层 来自 四川成都
so good! Thank you very much!
发表于 2010-7-10 13:44:24 | 显示全部楼层 来自 北京
谢谢分享~~
GMT+8, 2024-10-2 20:32 , Processed in 0.045997 second(s), 14 queries , Gzip On, MemCache On.
