- 9
- 2008-1-20
本UDF可以根据需要,添加更多的运动,支持多个运动,支持并行,支持信息自动保存,与大家共同研究。
# include "udf.h"
static real G = 9.80; /* 重力*/
static real valve_M = 0.1; /* 质量*/
static real valve_S = 0.0; /* 位移*/
static real valve_V = 0.0; /* 速度*/
static real valve_F = 0.0; /*受力*/
static int is_valve = 0; /* 判断物体是否运动的阀值*/
DEFINE_CG_MOTION(valve, dt, vel, omega, time, dtime)
#if !RP_HOST
Thread *t;
Domain *d;
real dv, CG[ND_ND], force[3], moment[3];
if (!Data_Valid_P ())
Message0("\n\nNo data->No mesh motion!!!\n\n");
return;
/* 速度赋值 */
NV_S (vel, =, 0.0);
NV_S (omega, =, 0.0);
/* 力的计算*/
d = THREAD_DOMAIN (DT_THREAD ((Dynamic_Thread *)dt));
t = DT_THREAD(dt);
NV_S (CG, =, 0.0);
Compute_Force_And_Moment (d, t, CG, force, moment, FALSE);
/* 计算力的变化 */
dv = dtime * (force[0] - G * valve_M) / valve_M;
if(is_valve == 0 && dv >= 0.0)
is_valve = 1;
Message0("\n\n============================== BEGIN VALVE MOTION INFO ==============================\n");
Message0("\n VALVE BEGIN MOVE! \n");
Message0("\n============================== END VALVE MOTION INFO ==============================\n");
if(is_valve == 0 && dv < 0.0) {
dv = 0.0;
valve_V += dv;
if(valve_S >= 0.010)
valve_V = 0.0;
valve_S += valve_V * dtime;
/* 设置x方向速度*/
vel[0] = valve_V;
valve_F = force[0];
Message0("\ntime=%.5e F(x)=%.4e S(x)=%.6e V(x)=%.6e move?=%d\n", time, force[0], valve_S, valve_V, is_valve);
#endif
node_to_host_real_1(valve_S);
node_to_host_real_1(valve_V);
node_to_host_real_1(valve_F);
node_to_host_int_1(is_valve);
node_to_host_real(vel, ND_ND);
node_to_host_real(omega, ND_ND);
/* 写数据函数*/
static void write_data(FILE *fp)
fprintf(fp, "%e ", valve_V);
fprintf(fp, "\n");
fprintf(fp, "%e ", valve_S);
fprintf(fp, "\n");
fprintf(fp, "%e ", valve_F);
fprintf(fp, "\n");
fprintf(fp, "%d ", is_valve);
fprintf(fp, "\n");
/* 读数据函数*/
static void read_data(FILE * fp)
fscanf(fp, "%e", &valve_V);
fscanf(fp, "%e", &valve_S);
fscanf(fp, "%e", &valve_F);
fscanf(fp, "%d", &is_valve);
fscanf(fp, "%e", &ball_V);
fscanf(fp, "%e", &ball_S);
fscanf(fp, "%e", &ball_F);
fscanf(fp, "%d", &is_ball);
DEFINE_RW_FILE(reader, fp)
Message0("\n\n============================== BEGIN UDF INFOMATION ==============================\n");
Message0("\nReading UDF data from data file...\n");
#if PARALLEL
#if RP_HOST
read_data(fp);
#endif
#else
read_data(fp);
#endif
host_to_node_real_1(valve_V);
host_to_node_real_1(valve_S);
host_to_node_real_1(valve_F);
host_to_node_int_1(is_valve);
host_to_node_real_1(ball_V);
host_to_node_real_1(ball_S);
host_to_node_real_1(ball_F);
host_to_node_int_1(is_ball);
Message0("\n------------------------------ BEGIN VALVE MOTION INFO ------------------------------\n");
Message0("\nS(x)=%.6e V(x)=%.6e F(x)=%.4e move?=%d\n", valve_S, valve_V, valve_F, is_valve);
Message0("\n------------------------------ END VALVE MOTION INFO ------------------------------\n");
Message0("\n------------------------------ BEGIN BALL MOTION INFO ------------------------------\n");
Message0("\nS(x)=%.6e V(x)=%.6e F(x)=%.4e move?=%d\n", ball_S, ball_V, ball_F, is_ball);
Message0("\n------------------------------- END BALL MOTION INFO -------------------------------\n");
Message0("\n================================ END UDF INFOMATION ================================\n\n");
DEFINE_RW_FILE(writer, fp)
Message0("\n\nWriting UDF data to data file...\n");
#if PARALLEL
#if RP_HOST
write_data(fp);
#endif
#else
write_data(fp);
#endif
2
