*** WARNING *** SUPPRESSED MESSAGE CP = 113.953 TIME= 20:36:35
The calculated reference FORCE CONVERGENCE VALUE = 1.023387512E-06 is
less than the default minimum of 1 (MINREF field of CNVTOL command).
Check results carefully.
The calculated reference HT FLOW CONVERGENCE VALUE= 0 is less than the
default minimum of 1E-6 (MINREF field of CNVTOL command). Check
results carefully.
*** WARNING *** SUPPRESSED MESSAGE CP = 115.391 TIME= 20:36:38
There are 2 small equation solver pivot terms. May be a transitional
effect caused by the Newton-Raphson logic. 各位高人上面几项警告是什么意思。不胜感激
