FINISH
/CLEAR
/COM, Structural
*SET,x,12 ! 接触部位划分的线数
/PREP7
ET,1,PLANE42
ET,2,TARGE169
ET,3,CONTA175
R,1,,,0.1, 0.1,,
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDATA,EX,1,,2.06e11
MPDATA,PRXY,1,,0.3
save
PCIRC,150,332/2,-85,-95, ! 画截面
PCIRC,420/2,392/2,-85,-95,
wpoff,0,-181
CSYS,4
PCIRC,15, ,0,360,
CSYS,1
/PNUM,AREA,1
/REPLOT
SAVE
csys,0 ! 生成接触面和目标面
WPAVE,0,0,0
wpoff,0,-332/2
CSYS,4
PCIRC,3, ,0,360,
CSYS,0
WPAVE,0,0,0
CSYS,0
wpoff,0,-392/2+0.2
CSYS,4
PCIRC,3, ,0,360,
save
FLST,2,5,5,ORDE,2 ! 对滚子OVERLAP并用工作台切割生成接触区域最后再粘接
FITEM,2,1
FITEM,2,-5
AOVLAP,P51X
FLST,2,4,5,ORDE,4
FITEM,2,6
FITEM,2,8
FITEM,2,10
FITEM,2,12
ADELE,P51X, , ,1
wpro,,,-90.000000
FLST,2,5,5,ORDE,5
FITEM,2,7
FITEM,2,9
FITEM,2,11
FITEM,2,13
FITEM,2,16
ASBW,P51X
FLST,2,6,5,ORDE,6
FITEM,2,2
FITEM,2,4
FITEM,2,6
FITEM,2,8
FITEM,2,12
FITEM,2,17
AGLUE,P51X
save
FLST,5,6,4,ORDE,6 ! 划分接触区域的线并mesh面
FITEM,5,7
FITEM,5,10
FITEM,5,22
FITEM,5,28
FITEM,5,34
FITEM,5,37
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,x,10, , , ,1
FLST,5,4,4,ORDE,2
FITEM,5,49
FITEM,5,-52
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,30, , , , ,1
MSHAPE,0,2D
MSHKEY,1
FLST,5,4,5,ORDE,4
FITEM,5,2
FITEM,5,4
FITEM,5,6
FITEM,5,8
CM,_Y,AREA
ASEL, , , ,P51X
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
MSHKEY,0
FLST,5,2,5,ORDE,2
FITEM,5,12
FITEM,5,17
CM,_Y,AREA
ASEL, , , ,P51X
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
save
FLST,2,3,5,ORDE,3 ! 对内外圈进行粘接
FITEM,2,1
FITEM,2,3
FITEM,2,14
AGLUE,P51X
FLST,2,3,5,ORDE,3
FITEM,2,5
FITEM,2,10
FITEM,2,15
AGLUE,P51X
save
FLST,5,3,4,ORDE,3 ! 划分内圈接触区域网格
FITEM,5,1
FITEM,5,21
FITEM,5,25
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
MSHKEY,1
FLST,5,2,5,ORDE,2
FITEM,5,1
FITEM,5,3
CM,_Y,AREA
ASEL, , , ,P51X
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
save
FLST,5,3,4,ORDE,3 ! 划分外圈接触区域网格
FITEM,5,9
FITEM,5,33
FITEM,5,40
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
FLST,5,2,5,ORDE,2
FITEM,5,5
FITEM,5,10
CM,_Y,AREA
ASEL, , , ,P51X
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
MSHKEY,0
MSHAPE,1,2D
FLST,5,2,5,ORDE,2
FITEM,5,14
FITEM,5,-15
CM,_Y,AREA
ASEL, , , ,P51X
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
SAVE
lsel,s,line,,28 ! 下面是接触对的设置
nsll,,1
cm,cotac1,node
real,1
type,3
esurf
lsel,s,line,,25
nsll,,1
cm,targe1,node
real,1
type,2
esurf
lsel,s,line,,22
nsll,,1
cm,cotac,node
real,1
type,3
esurf
lsel,s,line,,21
nsll,,1
cm,targe,node
real,1
type,2
esurf
lsel,s,line,,34
nsll,,1
cm,cotac2,node
real,1
type,3
esurf
lsel,s,line,,33
nsll,,1
cm,targe2,node
real,1
type,2
esurf
lsel,s,line,,37
nsll,,1
cm,cotac3,node
real,1
type,3
esurf
lsel,s,line,,40
nsll,,1
cm,targe3,node
real,1
type,2
esurf
ALLSEL,ALL
SAVE
FLST,2,1,4,ORDE,1 !添加约束和载荷
FITEM,2,5
/GO
DL,P51X, ,ALL,0
FLST,2,3,5,ORDE,3
FITEM,2,1
FITEM,2,3
FITEM,2,14
/GO
DA,P51X,UX,0
FLST,2,1,4,ORDE,1
FITEM,2,3
/GO
SFL,P51X,PRES,1000,
CSYS,1
FLST,5,6,5,ORDE,6
FITEM,5,2
FITEM,5,4
FITEM,5,6
FITEM,5,8
FITEM,5,12
FITEM,5,17
ASEL,S, , ,P51X
NSLA,S,1
NPLOT
FLST,2,4478,1,ORDE,2
FITEM,2,1
FITEM,2,-4478
NROTAT,P51X
ALLSEL,ALL
save
FINISH ! 求解设置
/SOL
NSUBST,10,50,5
AUTOTS,1
TIME,1
/STATUS,SOLU
SOLVE
附件是最后的结果,似乎发生了穿透! |
