- 2008-5-18
楼主 |
发表于 2008-5-18 05:54:05
来自 武汉大学工学部
代码
代码贴上,请各位帮忙看看~
function out=teqcplot(files);
% TEQCPLOT Read and plot TEQC report files
% TEQC is the Toolkit for GPS/GLONASS/SBAS Data used to solve
% many pre-processing problems with GPS, GLONASS, and SBAS data:
% TEQC stands for Translation, Editing, and Quality Check
% More info here: http://facility.unavco.org/software/teqc/teqc.html
% TEQCPLOT(FILENAME) returns the content of a TEQC reportfile in
% a figure (and a struct variable).
% Input argument FILENAME is optional.
% Valid TEQC report files are:
% FORMAT DESCRIPTION
% *.sn1 Signal to noise ratio (S/N) Carrier L1
% *.sn2 Signal to noise ratio (S/N) Carrier L2
% *.iod Derivative of ionospheric delay observable (m/s)
% *.ion Ionospheric delay observable (m)
% *.mp1 Multipath Carrier L1
% *.mp2 Multipath Carrier L2
% *.azi Satellite azimuthal data (degrees)
% *.ele Satellite elevation data (degrees)
% Jim Hedfors, Uppsala University, 2005
% Comments and requests for more TEQC Matlab tools to:
% jim.hedfors@gmail.com
% FUNCTION: READER & PLOTTER ++++++++++++++++++++++++++++++++++++++++++++++
if nargin==0
[filen,path]=uigetfile('*.sn1;*.sn2;*.iod;*.ion;*.mp1;*.mp2;*.azi;*.ele',...
'Pick your TEQC report file');
else
[path,filen,ext]=fileparts(files);
path=[path '\'];
filen={[filen ext]};
end
file=char(filen);
[A]=importdata([path file],'\t');
SAT(1:length(A),1:32)=NaN;
n=0;i=5;
sats=str2num(A{i});
snyggfilen=strrep(filen,'_','-');
h=waitbar(0,['Please wait... Importing ' char(snyggfilen)]);
while i<length(A)-1;
waitbar(i/length(A),h);drawnow
n=n+1;
i=i+1;
if sats~=0;
SAT(n,sats(2:end))=str2num(A{i});
i=i+1;
end
if str2num(A{i})~=-1;
sats=str2num(A{i});
end
end
close(h);
sat=SAT(1:n+1,:);
t_samp=char(A(3));
mjl=char(A(4));
T_SAMP=str2num(t_samp(max(find(t_samp==' ')):end));
MJL_START=str2num(mjl(max(find(mjl==' ')):end));
MJL(1)=MJL_START;
for i=2:length(sat);
MJL(i)=MJL_START+i*T_SAMP/60/60/24;
end
JD=mjl2jd(MJL);
[type,maxy,miny]=get_filetype(file);
figure;box on;hold on
pcolor(JD',1:32,sat')
set(gcf,'renderer','zbuffer');
shading flat
set(gca,'xticklabel',[JD]);
set(gca,'xlim',[JD(1) JD(end)])
dateaxis('X',13)
cbar('v',[miny maxy],type);
set(gca,'ylim',[1 33])
set(gca,'ytick',[1.5:1:32.5])
set(gca,'yticklabel',['S01';'S02';'S03';'S04';'S05';'S06';...
'S07';'S08';'S09';'S10';'S11';'S12';...
'S13';'S14';'S15';'S16';'S17';'S18';...
'S19';'S20';'S21';'S22';'S23';'S24';...
'S25';'S26';'S27';'S28';'S29';'S30';...
'S31';'S32']);
set(gca,'fontsize',7);
colormap(flipud(jet));
caxis([miny maxy]);
xlabel([datestr(JD(1)) ' |-------- T Samp: ' num2str(T_SAMP) ' s --------| ' datestr(JD(end))])
ylabel('SVS')
timestr=secs2hms(length(sat));
T=title(['TEQC Report file: ' strrep(file,'_','-')]);
set(T,'fontsize',8)
out.(file(end-2:end))=sat;
out.T_samp=T_SAMP;
out.Start=datestr(JD(1));
out.Stop=datestr(JD(end));
% FUNCTION: MJL DAYS TO JULIAN DAYS +++++++++++++++++++++++++++++++
function [out]=mjl2jd(in)
out=in+678941.999999741;
% FUNCTION: GET FILETYPE INFO +++++++++++++++++++++++++++++++++++++
function [out,maxy,miny]=get_filetype(teqfile);
[path,name,ext,ver]=fileparts(teqfile);
switch ext
case '.sn1'
out='Signal to noise ratio S/N L1';
maxy=10;
miny=0;
case '.sn2'
out='Signal to noise ratio S/N L2';
maxy=10;
miny=0;
case '.mp1'
out='Multipath L1';
maxy=1;
miny=-1;
case '.mp2'
out='Multipath L2';
maxy=1;
miny=-1;
case '.iod'
out='Derivative of ionospheric delay observable (m/s)';
maxy=1;
miny=-1;
case '.ion'
maxy=2;
miny=-2;
out='Ionospheric delay observable (m)';
case '.ele'
maxy=90;
miny=0;
out='Satellite elevation data';
case '.azi'
maxy=180;
miny=-180;
out='Satellite azimuthal data';
otherwise
disp('Somethings wrong..!')
end
% FUNCTION: PLACE A MODIFIED COLORBAR ++++++++++++++++++++++++++++++
function CB=cbar(loc,range,label);
% CB = cbar(loc,range,label)
% places a colorbar at:
% loc = 'v' in vertical or 'h' in horizontal
% position in current figure scaled between:
% range = [min max] with a:
% label = 'string'.
% fontsize is reduced to 10 and width of bar is half default.
% Example: [X,Y,Z]=peaks(25);
% range=[min(min(Z)) max(max(Z))];
% pcolor(X,Y,Z);
% cbar('v',range,'Elevation (m)')
caxis([range(1) range(2)]);
switch loc
case 'v'
CB=colorbar('vertical');
set(CB,'ylim',[range(1) range(2)]);
POS=get(CB,'position');
set(CB,'position',[POS(1) POS(2) 0.03 POS(4)]);
set(CB,'fontsize',8);
set(get(CB,'ylabel'),'string',label);
set(CB,'box','on')
case 'h'
CB=colorbar('horizontal');
set(CB,'xlim',[range(1) range(2)]);
set(CB,'position',[POS(1) POS(2) POS(3) 0.03]);
set(get(CB,'xlabel'),'string',label)
end
% FUNCTION: SECONDS TO HOURS, MINUTES and SECONDS ++++++++++++++++
function timestr=secs2hms(SECS)
HOURS=SECS/60/60;
hours=floor(HOURS);
MINUTES=(HOURS-hours)*60;
minutes=floor(MINUTES);
seconds=(MINUTES-minutes)*60;
HH=num2str(hours);
MM=num2str(minutes);
SS=num2str(seconds);
if seconds<10;
SS=['0' num2str(SS)];
else
SS=num2str(SS);
end
if minutes<10;
MM=['0' num2str(MM)];
else
MM=num2str(MM);
end
timestr=[HH ':' MM ':' SS];
% EOF +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ |
