- 2008-4-3
楼主 |
发表于 2008-8-22 15:48:53
来自 湖南长沙
感谢各位的帮助。我的工作盘还有42.7G的空间,且是NTFS文件系统。我的系统是32位的中文XP。
我的模型有66万个网格,所以体积比较大,我的另外一个模型,fem文件有99M,可以正常计算。
更详细的报错如下(我用8.0、9.0都尝试算过,都不行,这是9.0的报错):
*** OptiStruct defaults set from:
install config file: d:\Altair\hw9.0/hwsolvers/hwsolver.cfg
1 PARAM(s) were set:
AUTOSPC ,YES
RAM: 1362 MB total, 0 MB used.
Data arrays: 133 total, 105 allocated.
DATA SET size 0 MB, ram_disk 0 MB
DATASET USAGE: ndirs: 1, nfiles 1, nsets: 0, nblocks: 0, mode: 8
DIR: 0, size 0[B], path "F:/CY/GSM--finall/04/xdb/" num_files 1
OptiStruct crash exit at: 08/21/08 11:46:51
Trace point: 1005
CPU times[sec]: user 87.750, system 2.641, Wall clock 90.391
Command line arguments:
F:\CY\GSM--finall\04\xdb\xdb-test.fem
-exec=OS
File stats with output file root: xdb-test
Warning - file sizes might be truncat
Work directory: "./" Free size 83885 MB
0 xdb-test.1980_scr.s40
Work directory: "F:/CY/GSM--finall/04/xdb/" Free size 43730 MB
115929960 xdb-test.fem
24096586 xdb-test.hm
1705 xdb-test.out
493 xdb-test.stat
0 xdb-test_1980_00.scr |
