查看: 924|回复: 18
在optistruct里怎么添加一个随时间变化的扭矩呢
发表于 2008-9-11 17:04:57 | 显示全部楼层 |阅读模式 来自 广东广州
请问一下高手,在optistruct里怎么添加一个随时间变化的扭矩呢?谢谢!
发表于 2008-9-11 21:39:55 | 显示全部楼层 来自 上海闵行区
多看看帮助文件,里面东西很多的。
To create a moment:
1. Select the create sub-panel.
2. Use the switch to choose the entities to apply the force to: nodes, points, sets or comps.
In any case, the moments are applied to nodes; this selection simply determines how those nodes are selected.  Geometric points select the nodes at which they exist.  Comps select all of the nodes contained within the chosen component.
If you choose comps or sets, HyperMesh draws the moments using a single indicator.  As a result, a new button called display appears.  This allows you to indicate where in the model you wish the indicator to be drawn, and requires these additional steps:
- Click display.
- Pick a location in your model, or click display again to specify x, y, z coordinates.
3. Indicate the nodes where you want to place moments by picking them on your model, or click nodes and choose the nodes from the extended entity selection menu.
4. Click the toggle to create the moment in the global system or the local system.
- If you select local system, click system and enter the ID of the desired system.
5. Specify the magnitude and direction of the moment in one of several ways.  Each method is chosen from the upper of two adjacent switches.
- To specify the direction and magnitude of the moment by typing in the moment components, type in the x, y, and z values of the components.
- If you want to use the vector magnitude method, type in a magnitude, then use the plane and vector selector to specify the vector along which the moment should act.
- If you select the curve, vector option (for moments that are time-dependent), specify a magnitude (y-scale) for the curve.  Next, click the curve field twice to select from a list and then use the plane and vector selector to specify a direction, if necessary.  Finally, specify a factor for the curve’s xscale.  This allows you to use the same curve for many different cases, but vary the scale of its intensity or time to match the needs of your current force.
- If you choose the curve, components option, type in the X, Y, and Z components to define the direction and magnitude--for example, (2,2,2) will be twice the magnitude of (1,1,1).  Next, click the curve field twice to select from a list.  Finally, specify a factor for the curve’s xscale.  This allows you to use the same curve for many different cases, but vary the scale of its intensity or time to match your current needs.
- If you choose to define the moment via an equation, type the equation into the text box.  Optionally, you can also use the plane and vector selector to specify a direction, and select the coordinate system to which the vector corresponds.
- To interpolate moments from a saved file or existing loads, select linear interpolation (Note that linear interpolation only works with shell elements).  You can then select the desired nodes to which you wish to add loads, and pick 3 or more existing loads that enclose those nodes.  When you interpolate, HyperMesh uses a linear function to create additional loads on the selected nodes, with magnitudes based on the magnitudes of the loads that you had selected:
The search radius is a search distance to find the loads which are within that distance from a centroid or node on which a load is being interpolated. HyperMesh uses the nearest 3 loads located within that distance to create the load at the centroid or node by linear interpolation. Linear interpolation uses a triangulation method, so if it finds fewer than 3 loads within that distance no interpolation takes place. While reading the initial loads from a file, if linear interpolation is not possible because the search radius is too small, the original loads are simply applied to the nearest centroid or node.
- To interpolate and extrapolate moments from existing loads, select field loads.  You can then select the desired nodes to which you wish to add loads, and any existing loads on which you wish to base additional forces.  When you create, HyperMesh uses a complex function to create additional loads on all of the selected nodes, with magnitudes based on the magnitudes of the loads that you had selected.
Note that this version differs from linear interpolation both in the way that the load magnitudes are determined, and also in the fact that it can be applied to nodes outside the boundaries of the chosen existing loads.
[ 本帖最后由 Pheigoe 于 2008-9-11 21:41 编辑 ]
 楼主| 发表于 2008-9-11 22:09:36 | 显示全部楼层 来自 广东广州
非常感谢你的回复。
我知道帮助文件里很多东西。东西太多了,具体的问题就不好找,不可能去从头看到尾吧。可能还是方法不对,比如,我想输出动态载荷的加载曲线,我就不知道该输入什么关键词才能在帮助文件里找到相关的内容。
发表于 2009-3-30 11:25:51 | 显示全部楼层 来自 江苏镇江
说的有道理
发表于 2009-4-26 15:01:36 | 显示全部楼层 来自 广西柳州
帮助文件里面全英文,我英语没过4级。。。。。。。
发表于 2009-4-30 14:47:11 | 显示全部楼层 来自 湖北武汉
这些软件学习起来必定要有点英语基础
很多英文的比翻译的要好些
发表于 2009-7-11 12:03:35 | 显示全部楼层 来自 湖南长沙
其实帮组里的英语很简单,没什么语法要求,懂基本的就能看懂,边上配个金山词霸,开桌面取词就可以了,不过有的要在专业字典上才能查到
发表于 2009-7-14 11:18:40 | 显示全部楼层 来自 重庆沙坪坝区
路过看看
学习
发表于 2009-8-23 18:59:46 | 显示全部楼层 来自 上海杨浦区
帮助时很有用的,尤其对于新手
发表于 2009-9-30 09:44:35 | 显示全部楼层 来自 广东深圳
帮助文档是比较好地!!
发表于 2009-10-17 16:23:29 | 显示全部楼层 来自 山东威海
有限元软件最好的学习资料就是帮助,大家说对吧!
发表于 2010-8-26 18:29:18 | 显示全部楼层 来自 江苏镇江
对是对的。。。。。。。
发表于 2010-9-13 08:22:44 | 显示全部楼层 来自 江苏南京
帮助里的文件的确太多
发表于 2010-9-18 08:57:23 | 显示全部楼层 来自 大连理工大学
帮助看不懂!
发表于 2011-5-12 19:37:52 | 显示全部楼层 来自 吉林长春
学习中
xiexei
发表于 2011-5-16 19:28:36 | 显示全部楼层 来自 英国
thanks for the answer and it is correct and useful.
发表于 2011-7-28 00:21:48 | 显示全部楼层 来自 江苏无锡
学习学习,哎哎
发表于 2011-9-6 22:17:52 | 显示全部楼层 来自 山东
帮助时很有用的
发表于 2011-10-16 10:56:45 | 显示全部楼层 来自 河北石家庄
大家相互交流求进步
GMT+8, 2024-10-7 01:46 , Processed in 0.055087 second(s), 10 queries , Gzip On, MemCache On.
