- 2007-1-19
楼主 |
发表于 2008-10-24 10:15:54
来自 浙江温州
!-------------------------- Default Units for Model ---------------------------!
defaults units &
length = mm &
angle = deg &
force = newton &
mass = kg &
time = sec
defaults units &
coordinate_system_type = cartesian &
orientation_type = body313
!------------------------ Default Attributes for Model ------------------------!
defaults attributes &
inheritance = bottom_up &
icon_visibility = on &
grid_visibility = off &
size_of_icons = 50.0 &
spacing_for_grid = 1000.0
!------------------------------ Adams/View Model ------------------------------!
model create &
model_name = model_1
view erase
!--------------------------------- Materials ----------------------------------!
material create &
material_name = .model_1.steel &
youngs_modulus = 2.07E+005 &
poissons_ratio = 0.29 &
density = 7.801E-006
!-------------------------------- Rigid Parts ---------------------------------!
! Create parts and their dependent markers and graphics
!----------------------------------- ground -----------------------------------!
! ****** Ground Part ******
defaults model &
part_name = ground
defaults coordinate_system &
default_coordinate_system = .model_1.ground
! ****** Markers for current part ******
marker create &
marker_name = .model_1.ground.MARKER_3 &
adams_id = 3 &
location = 0.0, 0.0, 0.0 &
orientation = 0.0d, 0.0d, 0.0d
part create rigid_body mass_properties &
part_name = .model_1.ground &
material_type = .model_1.steel
part attributes &
name_visibility = off
!----------------------------------- PART_2 -----------------------------------!
part create rigid_body name_and_position &
part_name = .model_1.PART_2 &
adams_id = 2 &
default_coordinate_system = .model_1.PART_2
marker create &
marker_name = .model_1.PART_2.MARKER_1 &
adams_id = 1 &
marker create &
marker_name = .model_1.PART_2.MARKER_2 &
adams_id = 2 &
location = 450.0, 0.0, 0.0 &
marker create &
marker_name = .model_1.PART_2.cm &
location = 225.0, 0.0, 0.0 &
marker create &
marker_name = .model_1.PART_2.MARKER_4 &
adams_id = 4 &
! ****** Graphics for current part ******
geometry create shape link &
link_name = .model_1.PART_2.LINK_1 &
i_marker = .model_1.PART_2.MARKER_1 &
j_marker = .model_1.PART_2.MARKER_2 &
width = 45.0 &
depth = 22.5
part attributes &
color = RED &
!----------------------------------- Joints -----------------------------------!
constraint create joint revolute &
joint_name = .model_1.JOINT_1 &
adams_id = 1 &
i_marker_name = .model_1.ground.MARKER_3 &
j_marker_name = .model_1.PART_2.MARKER_4
constraint attributes &
constraint_name = .model_1.JOINT_1 &
!----------------------------------- Forces -----------------------------------!
!---------------------------------- Motions -----------------------------------!
constraint create motion_generator &
motion_name = .model_1.MOTION_1 &
adams_id = 1 &
type_of_freedom = rotational &
function = ""
constraint_name = .model_1.MOTION_1 &
!---------------------------------- Accgrav -----------------------------------!
force create body gravitational &
gravity_field_name = gravity &
x_component_gravity = 0.0 &
y_component_gravity = -9806.65 &
z_component_gravity = 0.0
!----------------------------- Analysis settings ------------------------------!
!---------------------------- Function definitions ----------------------------!
constraint modify motion_generator &
function = "30.0d * time"
!--------------------------- Expression definitions ---------------------------!
default_coordinate_system = ground
geometry modify shape link &
width = (45.0mm) &
depth = (22.5mm)
material modify &
youngs_modulus = (2.07E+011(Newton/meter**2)) &
density = (7801.0(kg/meter**3))
model display &
model_name = model_1 |
