- 2007-6-7
我做单桩和土的地应力平衡可以成功,但是多加了一个桩就算不下去了,提示 ERROR: FIXED TIME INCREMENT IS TOO LARGE。
警告信息:
THE SLAVE SURFACES _PICKEDSURF8 AND _PICKEDSURF31 INTERSECT EACH OTHER. THEY
ARE PAIRED WITH MASTER SURFACES _PICKEDSURF7 AND _PICKEDSURF30 THAT ALSO
INTERSECT EACH OTHER. IF BOTH PAIRS ARE *CONTACT PAIRs, THESE TWO PAIRS
SHOULD NOT BE SIMULTANEOUSLY PRESENT IN A STEP BECAUSE OF POSSIBLE
CONVERGENCE PROBLEMS; USE *MODEL CHANGE,TYPE=CONTACT PAIR TO REMOVE ONE OF
THEM. IF BOTH ARE *TIE PAIRS, THE REDUNDANT TIES WILL BE REMOVED
AUTOMATICALLY. IF ONE PAIR IS *TIE AND ANOTHER IS *CONTACT PAIR, REMOVE ONE
OF THEM.
THE SLAVE SURFACES _PICKEDSURF10 AND _PICKEDSURF31 INTERSECT EACH OTHER. THEY
ARE PAIRED WITH MASTER SURFACES _PICKEDSURF9 AND _PICKEDSURF30 THAT ALSO
OF THEM.
THE SLAVE SURFACES _PICKEDSURF12 AND _PICKEDSURF33 INTERSECT EACH OTHER. THEY
ARE PAIRED WITH MASTER SURFACES _PICKEDSURF11 AND _PICKEDSURF32 THAT ALSO
OF THEM.
THE SLAVE SURFACES _PICKEDSURF14 AND _PICKEDSURF33 INTERSECT EACH OTHER. THEY
ARE PAIRED WITH MASTER SURFACES _PICKEDSURF13 AND _PICKEDSURF32 THAT ALSO
OF THEM.
For *tie pair (_pickedsurf31-_pickedsurf30), adjusted nodes with very small
adjustments were not printed. Specify *preprint,model=yes for complete
printout.
For *tie pair (_pickedsurf33-_pickedsurf32), adjusted nodes with very small
printout.
同样的接触设置方法,一个桩就成功了,多了一个桩就这么多错误,到底是什么原因?我查遍资料也没个介绍这个问题的!论坛上有不少朋友遇到过这个问题,好象也没有系统解决办法?有大侠指点下吗? |
