- 2008-11-25
请教大家:我以本论坛上formyjoy的教程 HyperMesh与Abaqus/Explicit的接口应用—— 模拟方盒跌落过程做练习,软件版本为hypermesh9.0,abaqus6.8,从hypermesh导出inp文件后,通过ABAQUS/CAE一model方式导入,在屏幕下方message area出现如下警告:
WARNING: Unknown element set BOX_PROP in part PART-1. This occurred while processing section keyword *SHELLSECTION. The keyword will be ignored.
WARNING: Node-based surfaces are not yet supported in Abaqus/CAE. The following node sets have been created in place of the corresponding node-based surfaces so they can be used in Abaqus/CAE.
Node Set Created Node-Based Surface
HM_COUPDIS_SURFACE_9201 HM_COUPDIS_SURFACE_9201
WARNING: Unknown assembly level element set TRUE. This occurred while processing rigid body definition. The rigid body definition will be ignored.
Warning: The elset: "BOX_PROP" is referenced in part: "PART-1" and should be assigned to this part. The set appears to be undefined.
box,ground等component的材料属性等都是通过创建protertity的方式赋予的,和教程有些差别。附上HMfile,请大家帮帮忙,谢谢大家了!
