- 2006-10-16
版主好我用一个简单的模型,建立GroupToGroupReport在结束的时候,运行目录里面就有一个GroupReport.xls和一个GroupReport.dat;但是一个大模型就不行了,虽然也有GroupReport.xls,可是没有GroupReport.dat。是不是模型复杂的时候GroupToGroupReport不够用了啊?
MSGF如下:
Model file: I:\20090104VacuumContainDeluxe\VaccumContainDeluxe.mf1
Current FE Model: 666
Current FE Study: DEFAULT FE STUDY
Current FE Study Notes:
None
Cpu time= 0.2 DATACH Module
Performing data checking...
Number of nodes 84151
Number of elements 91636
Number of fluid elements 5181
...done.
Cpu time= 12.1 ECHOS Module
Calculating geometrical parameters...
...done.
Cpu time= 15.3 COND Module
Calculating conductive conductances and capacitances...
...done.
Cpu time= 34.1 VUFAC Module
Calculating thermal couplings and geometric radiative parameters...
Number of shadowing surfaces = 325 created from 16615 elements
Cpu time= 44.8
Processing radiation request 1, 9480241 items are to be computed.
At Cpu time= 104.8 seconds the calculation is 24% complete.
At Cpu time= 151.6 seconds the calculation is 100% complete.
...done.
Cpu time= 151.6
Processing radiation request 2, 10956100 items are to be computed.
At Cpu time= 211.6 seconds the calculation is 36% complete.
At Cpu time= 232.4 seconds the calculation is 100% complete.
...done.
View factor calculation elemental subdivision summary:
No. of rays launched toward specular/transparent elements: 0
No. of view factors calculated with no elemental subdivision: 3253335
No. of view factors calculated with elemental subdivision 0: 3792296
No. of view factors calculated with elemental subdivision 1: 2459
No. of view factors calculated with elemental subdivision 2: 127
...done.
Cpu time= 951.3 GRAYB Module
Calculating radiative couplings and/or gray body matrices...
Creating radiative couplings...
View factor adjustment is performed...
Maximum view factor sum = 1.0061580 for element 89312 ALL_INI
Minimum view factor sum = 0.0651644 for element 37186 ALL_CON
See file REPF for complete report
Enclosure no. 1 contains 3079 elements
A complete element list of enclosure 1 appears in file groups.unv
with the group name:
Rad_enclosure0001_front_facing_000161
** WARNING **
** The view factor sum of some elements is < 8.000E-01
** Incomplete enclosures may exist in the model.
Enclosure no. 2 contains 3310 elements
A complete element list of enclosure 2 appears in file groups.unv
Rad_enclosure0002_front_facing_000162
** WARNING **
...done.
Cpu time= 1071.2 POWER Module
Calculating radiative heat loads...
...done.
Cpu time= 1073.4 POWER Module
...done.
Cpu time= 1075.6 POWER Module
...done.
Cpu time= 1077.7 MEREL Module
Performing element merging and elimination...
No. of elements merged: 43329, for details please see file REPF.
...done.
Cpu time= 1183.9 ANALYZER Module
Calculating temperatures...
Model Summary:
Number of elements = 257512
Number of hydraulic elements = 5181
Total number of conductances = 6599217
Number of linear conductances = 786409
Number of radiative conductances = 5697168
Number of 1-way fluid conductances = 5180
Number of follower conductances = 43329
Number of flow resistances = 5180
Number of convective conductances = 61951
Number of boundary elements = 132694
** WARNING **
** Thermal conjugate-gradient solver did not converge in 100 iterations.
** Solution automatically restarting with an iteration limit of 200
** Information: Residual= 7.499E-02 Target = 1.000E-08 Matrix fill= 10
** No user intervention required.
** Conjugate-gradient solver successfully converged after 193 iterations
** Information: Residual= 8.771E-09 Target = 1.000E-08 Matrix fill= 10
** WARNING **
** Thermal conjugate-gradient solver did not converge in 200 iterations.
** Information: Residual= 2.435E-06 Target = 1.000E-08 Matrix fill= 10
** Conjugate-gradient solver successfully converged after 38 iterations
** Information: Residual= 9.377E-09 Target = 1.000E-08 Matrix fill= 10
** WARNING **
** Information: Residual= 1.801E-07 Target = 1.000E-08 Matrix fill= 10
** Conjugate-gradient solver successfully converged after 3 iterations
** Information: Residual= 5.595E-09 Target = 1.000E-08 Matrix fill= 10
** WARNING **
** Information: Residual= 5.773E-08 Target = 1.000E-08 Matrix fill= 10
** Conjugate-gradient solver successfully converged after 2 iterations
** Information: Residual= 5.510E-08 Target = 1.000E-07 Matrix fill= 10
No. of iterations = 10 TDmax = 4.902E-04 at element 37437
Minimum temperature = -200.000 at element 75365 LN2_PIP
Maximum temperature = 45.354 at element 39036 ALL_INI
Average temperature = -130.407
Summary for fluid elements
Ambient pressure (absolute) = 1.014E+02
Ambient density = 1.207E-09
Ambient temperature = 2.000E+01
Average density = 7.069E-07
Average viscosity =
Maximum static pressure = 3.143E-02 at element 43556
Minimum static pressure =-3.815E-05 at element 93325
Maximum dynamic pressure = 3.535E-05 at element 41108
Minimum dynamic pressure = 0.000E+00 at element 93464
Maximum Mach no = 2.416E-29 at element 93464
Maximum total pressure = 3.146E-02 at element 93324
Minimum total pressure = 0.000E+00 at element 93325
PDmax = 0.000E+00
Total mass flow into sinks = 0.000E+00
Total mass flow from sinks = 0.000E+00
Deviation from mass balance = 0.000E+00
Summary for thermal elements:
Maximum heat balance deviation occurs at element 86128 ALL_INI
Heat flow into sinks = 8.326E+07
Heat flow from non-fluid sinks = 4.326E+07
Heat load into elements = 4.000E+07
Heat flow from fluid sinks = 0.000E+00
Deviation from heat balance =-2.760E+02
...done.
Cpu time= 1708.7 RSLTPOST Module
Performing result postprocessing...
Writing Temperature data on Elements to tmgtempe.unv...
Writing Temperature data on Nodes to tmgtempn.unv...
Writing Heat Flow Density data on Elements to tmghtfe.unv...
Writing Heat Flow Density data on Nodes to tmghtfn.unv...
Writing Absorbed Orbital Flux data on Elements to tmgabsf.unv...
Writing Incident Orbital Flux data on Elements to tmgincf.unv...
Writing Reflected Orbital Flux data on Elements to tmgreff.unv...
Writing Total Orbital Flux data on Elements to tmgtotf.unv...
...done.
Cpu time= 1736.8 End of run |
