问题描述:ansys ls-dyna:就是模拟炮弹(与弹壳连接部位带凹槽增加拔弹力)与弹壳通过45号钢模具连接紧固的装配过程。如附件中图rubber0所示为模型的半轴面,
实体为沿X轴对称的回转零件。图中面 啊,A1,A5为固定模具,A3为动模,A3向左挤压橡胶A4,橡胶A4变形后挤压,钢板A2,使得A2局部变形被橡胶压入A1模型的环形凹槽中。
问题:1、模型我已建立,采用轴对称平面单元162. 建的对不对?接触边我建面积模的时候是有共用线段线的,可以吗?
2、橡胶模型参数不知道,用的ANSYS自带的一个,我用的橡胶很硬,HS应该在70以上,您有参数吗?
3、摩擦建立时不知用那种?试了单面-自动和面-面-自动都不行,不会建立摩擦。
4、在以上条件下,静态加载,让A3面向左挤压橡胶A4,计算结果不对。橡胶穿透了钢板A2,而A2不变形,且位置移动了。
5、我想要的结果是计算动模A3,应该施加多大的力使钢板(弹壳收口处)被压入凹槽。
请各位百忙中帮我算算,谢谢!
建模过程如下:
/PREP7
ET,1,PLANE162
KEYOPT,1,3,1
KEYOPT,1,5,0
MP,DENS,1,7.85e-006 !*235钢板材料
MP,EX,1,210
MP,NUXY,1,0.29
TB,BISO,1,,,,
TBDAT,1,0.23
TBDAT,2,10
MP,DENS,2,7.85e-006
MP,EX,2,210
MP,NUXY,2,0.29
MP,DENS,3,7.85e-006
MP,EX,3,210
MP,NUXY,3,0.29
MP,DENS,4,7.85e-006
MP,EX,4,210
MP,NUXY,4,0.29
MP,DENS,5,2.82e-006
MP,NUXY,5,0.49967
TB,MOONEY,5,,,0,
TBDAT,1,0.293
TBDAT,2,0.177
KEYOPT,1,2,0
K,1,0,0,,
K,2,33,0,,
K,3,36,0,,
K,4,74,0,,
K,5,0,52.5,,
K,6,30,52.5,,
K,7,33,52.5,,
K,8,36.15,52.5,,
K,9,74,52.5,,
K,10,87,52.5,,
K,11,30,53.95,,
K,12,87,53.95,,
K,13,0,55,,
K,14,30,55,,
K,15,62,55,,
K,16,192,55,,
K,17,36,80,,
K,18,56,80,,
K,19,112,80,,
K,20,192,80,,
K,21,0,110,,
K,22,112,110,,
K,23,34.575,51.05,,
LSTR, 1, 4
LSTR, 4, 9
LSTR, 9, 8
LSTR, 7, 5
LSTR, 5, 1
LARC, 8, 7, 23
AL,1,2,3,4,5,6
LSTR, 6, 10
LSTR, 10, 12
LSTR, 12, 11
LSTR, 11, 6
AL,7,8,9,10
LSTR, 16, 20
LSTR, 20, 18
LSTR, 18, 15
LSTR, 15, 16
AL,11,12,13,14
LSTR, 15, 18
LSTR, 18, 17
LSTR, 17, 14
LSTR, 14, 15
AL,13,15,16,17
LSTR, 17, 19
LSTR, 19, 22
LSTR, 22, 21
LSTR, 21, 13
LSTR, 13, 14
AL,16,18,19,20,21,22
!* 划分网格 定义part
FLST,5,4,4,ORDE,3
FITEM,5,13
FITEM,5,15
FITEM,5,-17
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,10, , , , ,1
FLST,5,4,4,ORDE,4
FITEM,5,18
FITEM,5,-19
FITEM,5,21
FITEM,5,-22
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
FLST,5,3,4,ORDE,3
FITEM,5,11
FITEM,5,-12
FITEM,5,14
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
/ZOOM,1,SCRN,-0.085762,-0.020593,0.336093,-0.108651
LPLOT
FLST,5,2,4,ORDE,2
FITEM,5,7
FITEM,5,9
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,40, , , , ,1
FLST,5,2,4,ORDE,2
FITEM,5,8
FITEM,5,10
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,4, , , , ,1
TYPE, 1
MAT, 1
REAL,
ESYS, 0
SECNUM,
MSHAPE,0,2D
MSHKEY,0
CM,_Y,AREA
ASEL, , , , 2
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
APLOT
TYPE, 1
MAT, 5
REAL,
ESYS, 0
SECNUM,
CM,_Y,AREA
ASEL, , , , 4
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
APLOT
/AUTO,1
/REP,FAST
TYPE, 1
MAT, 2
REAL,
ESYS, 0
SECNUM,
CM,_Y,AREA
ASEL, , , , 3
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
CM,_Y,AREA
ASEL, , , , 5
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
TYPE, 1
MAT, 3
REAL,
ESYS, 0
SECNUM,
CM,_Y,AREA
ASEL, , , , 5
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
ACLEAR,_Y1
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
TYPE, 1
MAT, 4
REAL,
ESYS, 0
SECNUM,
CM,_Y,AREA
ASEL, , , , 1
CM,_Y1,AREA
CHKMSH,'AREA'
CMSEL,S,_Y
AMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
SAVE
EDPART,CREATE
EDCGEN,ASSC, , ,0,0,0,0,0, , , , ,0,10000000,0,0
FINISH |
