- 15
- 2008-7-20
发表于 2009-4-14 11:01:33
来自 黑龙江哈尔滨
不太明白楼主的意思。
你可以试试加个ode 或 试试命令 meshintegrate
Purpose
Integrate over arbitrary cross section
Syntax
I = meshintegrate(p,t,d)
I = meshintegrate(p,d)
I = meshintegrate(p)
Description
I = meshintegrate(p,t,d) computes the integral I over the mesh given by p and t, with values (for each point) in d. d is of size 1-by-np, where np is the number of points in p (=size(p,2)). The elements are considered to be linear.
I = meshintegrate(p,d) assumes t=[1,2,3,... (np-1) ; 2,3,4,... np], (where np=size(p,2)), i.e., that the mesh is a line and that the points in p are sorted.
I = meshintegrate(p) calls meshintegrate(p(1,, p(2,:)).
This function is useful for computing integrals along cross sections plotted with postcrossplot, in which case p, t, and d are extracted from the output when the property outtype is set to postdata.
Examples
Line integral in 2D:
% Just set up a problem:
clear fem
fem.geom = circ2+rect2;
fem.mesh = meshinit(fem);
fem.shape = 2; fem.equ.c = 1; fem.equ.f = 1; fem.bnd.h = 1;
fem.xmesh = meshextend(fem);
fem.sol = femstatic(fem);
% Make a cross-section plot, with output being a postdata
% structure
pd = postcrossplot(fem,1,[0 1;0 1],'lindata','u',... 'npoints',100,'outtype','postdata');
% Call meshintegrate:
I = meshintegrate(pd.p);
Line integral in 3D:
clear fem, fem.geom = block3;
fem.mesh = meshinit(fem,'hmax',0.15);
fem.shape = 2;
fem.bnd.h = {1 1 0 0 1 1};
% Make cross-section plot:
pd = postcrossplot(fem,1,[0 1;0 1;0 1],'lindata','u',... 'npoints',100,'outtype','postdata');
Surface integral in 3D using the same problem as above:
pd = postcrossplot(fem,2,[0 0 0;0 1 0;1 0 1]','surfdata','u',...outtype','postdata');
I = meshintegrate(pd.p, pd.t, pd.d)
This function only works for lines and surfaces actually intersecting the geometry. For plots along geometry boundaries or edges (or 1-D subdomains), better results are achieved using postint.
Cautionary
This function is not implemented for 3-D elements, i.e., when T has four rows.
See also
postcrossplot, postint |
