- 3
- 2005-4-18
WARNING: Model .model_1 is no longer compatible with Adams/Solver (FORTRAN).
.model_1.CONTACT_1 may be causing the incompatibility because of one or more
of the following:
- Objects of type Contact are not compatible with Adams/Solver (FORTRAN).
- The topology of the model has changed so .model_1.CONTACT_1
is no longer connected in a way that is compatible with
- An attribute of .model_1.CONTACT_1 is no longer compatible with
If you intend to use Adams/Solver (FORTRAN), you must change
your model to eliminate the incompatibility. For more information,
see the online help for the object listed.
If you do not want to use Adams/Solver (FORTRAN), then be sure that you
set your preferences so Adams/Solver (C++) is the default as follows:
1) From the Settings menu, point to Solver and then select either
Solver Executable or Preferences, depending on the product
you are using.
2) To learn more, press F1 in the dialog box.
在VIEW中出现上述提示后把Settings——》Solver ——》Executable 菜单中改为了C++
但重新添加刚柔接触时还是反复出现上述提示
该怎么改呢? |
