- 2008-10-11
[Prolog]
Name=Prüfling 1
Comment=
Heading=
Line0=Antenne: vertikal
Line1=
Line2=
Line3=
Line4=
Line5=
Line6=
Param0=bis 30MHz: Schritt: Y=0,12 dB lin, X=0,012 MHz lin, t=50 ms, Peak, 12 kHz, Meßbereich 60 dB, Low Noise, Vorverstärker ein, Rohde&Schwarz ESI
Param1=bis 300MHz: Schritt: Y=0,12 dB lin, X=0,12 MHz lin, t=50 ms, Max Peak, 120 kHz, Meßbereich 50 dB, Low Noise, Vorverstärker ein, Rohde&Schwarz ESI
Param2=bis 1000MHz: Schritt: Y=0,12 dB lin, X=0,12 MHz lin, t=50 ms, Max Peak, 120 kHz, Meßbereich 50 dB, Low Noise, Vorverstärker ein, Rohde&Schwarz ESI
Param3=
Param4=
Param5=
Param6=
Param7=
Param8=
Param9=
Tester=
No=
DateTime=07.08.2008 11:11:12
StartTime=07.08.2008 09:31:22
XUnit=MHz
YUnit=dBµV/m
[Points]
3.00000000000000E+0001 1.48604441324867E+0001 07.08.2008 11:07:36 /*
3.01200000000000E+0001 1.50319517985027E+0001 07.08.2008 11:07:36 /*
3.02400000000000E+0001 1.39142291178387E+0001 07.08.2008 11:07:36 /*
3.03600000000000E+0001 1.48432746256507E+0001 07.08.2008 11:07:36 /*
3.04800000000000E+0001 1.42278331339517E+0001 07.08.2008 11:07:36 /*
3.06000000000000E+0001 1.39949828898117E+0001 07.08.2008 11:07:36 /*
3.07200000000000E+0001 1.47304325113937E+0001 07.08.2008 11:07:36 /*
3.08400000000000E+0001 1.48044212565107E+0001 07.08.2008 11:07:36 /*
3.09600000000000E+0001 1.47759319742837E+0001 07.08.2008 11:07:37 /*
3.10800000000000E+0001 1.44435028727214E+0001 07.08.2008 11:07:37 /*
3.12000000000000E+0001 1.46629536539717E+0001 07.08.2008 11:07:37 /*
3.13200000000000E+0001 1.52619668131507E+0001 07.08.2008 11:07:37 /*
3.14400000000000E+0001 1.45609921793620E+0001 07.08.2008 11:07:37 /*
3.15600000000000E+0001 1.46006105021157E+0001 07.08.2008 11:07:37 /*
3.16800000000000E+0001 1.48270192911787E+0001 07.08.2008 11:07:37 /*
3.18000000000000E+0001 1.51383050944007E+0001 07.08.2008 11:07:37 /*
3.19200000000000E+0001 1.49179517985027E+0001 07.08.2008 11:07:37 /*
3.20400000000000E+0001 1.49812975382487E+0001 07.08.2008 11:07:37 /*
3.21600000000000E+0001 1.47697485636397E+0001 07.08.2008 11:07:38 /*
3.22800000000000E+0001 1.44008891031901E+0001 07.08.2008 11:07:38 /*
3.24000000000000E+0001 1.38933730265297E+0001 07.08.2008 11:07:38 /*
3.25200000000000E+0001 1.50191043253577E+0001 07.08.2008 11:07:38 /*
3.26400000000000E+0001 1.52193214029947E+0001 07.08.2008 11:07:38 /*
3.27600000000000E+0001 1.68091335123667E+0001 07.08.2008 11:07:38 /*
3.28800000000000E+0001 1.46231811564127E+0001 07.08.2008 11:07:38 /*
3.30000000000000E+0001 1.41715503946937E+0001 07.08.2008 11:07:38 /*
3.31200000000000E+0001 1.46532539835617E+0001 07.08.2008 11:07:38 /*
3.32400000000000E+0001 1.46258785929367E+0001 07.08.2008 11:07:38 /*
3.33600000000000E+0001 1.41068497599287E+0001 07.08.2008 11:07:39 /*
3.34800000000000E+0001 1.46777333414717E+0001 07.08.2008 11:07:39 /*
3.36000000000000E+0001 1.40573861490887E+0001 07.08.2008 11:07:39 /*
3.37200000000000E+0001 1.45518079386397E+0001 07.08.2008 11:07:39 /*
3.38400000000000E+0001 1.40470002970377E+0001 07.08.2008 11:07:39 /*
3.39600000000000E+0001 1.41992590006507E+0001 07.08.2008 11:07:39 /*
3.40800000000000E+0001 1.37054758341467E+0001 07.08.2008 11:07:39 /*
3.42000000000000E+0001 1.35344542032877E+0001 07.08.2008 11:07:39 /*
3.43200000000000E+0001 1.37995974283857E+0001 07.08.2008 11:07:39 /*
3.44400000000000E+0001 1.31457343058267E+0001 07.08.2008 11:07:39 /*
3.45600000000000E+0001 1.41630366495767E+0001 07.08.2008 11:07:39 /*
3.46800000000000E+0001 1.32808333780927E+0001 07.08.2008 11:07:40 /*
3.48000000000000E+0001 1.35832843424477E+0001 07.08.2008 11:07:40 /*
3.49200000000000E+0001 1.34062965250647E+0001 07.08.2008 11:07:40 /*
3.50400000000000E+0001 1.37218395304367E+0001 07.08.2008 11:07:40 /*
3.51600000000000E+0001 1.47485718058267E+0001 07.08.2008 11:07:40 /*
3.52800000000000E+0001 1.34328739664717E+0001 07.08.2008 11:07:40 /*
3.54000000000000E+0001 1.35124245402017E+0001 07.08.2008 11:07:40 /*
3.55200000000000E+0001 1.39999951334637E+0001 07.08.2008 11:07:40 /*
3.56400000000000E+0001 1.37270981974287E+0001 07.08.2008 11:07:40 /*
3.57600000000000E+0001 1.32982716959637E+0001 07.08.2008 11:07:40 /*
3.58800000000000E+0001 1.31760324137367E+0001 07.08.2008 11:07:41 /*
3.60000000000000E+0001 1.29634229532867E+0001 07.08.2008 11:07:41 /*
这些数据是EMC 的测量值,我想把它读入Matlab 中, 把后面的两列数据读出,并画图,第一列是连续的频率值,作为X轴,第二列是dBuv/m 作为Y 轴,同时数据头文件的描述想作为描述内容在TEXT 文本框中动态显示出来以对应于不同的Prüfling (样本), 非常感谢!! |
