- 2009-4-14
我的adams出问题了,一打开模型文件就出现如下错误信息(下面的信息只是打开某一个文件时出现的):ERROR: The modal neutral file "E:/cae_work/adams/examples/chapter_06/welding_robot_flex/arm_flex.mnf" referenced by flexible body .welding_robot.arm_flex was not found. Either the file is not in the proper location or the location of the file is not specified in the aview.pth file. First, examine your aview.pth file to see that it has an entry for .mnf files. Next, make sure that the file exists at the path specified in the aview.pth file.ERROR: The modal neutral file "E:/cae_work/adams/examples/chapter_06/welding_robot_flex/shoulder_flex.mnf" referenced by flexible body .welding_robot.shoulder_flex was not found. Either the file is not in the proper location or the location of the file is not specified in the aview.pth file. First, examine your aview.pth file to see that it has an entry for .mnf files. Next, make sure that the file exists at the path specified in the aview.pth file.ERROR: The modal neutral file "E:/cae_work/adams/examples/chapter_06/welding_robot_flex/trunk_flex.mnf" referenced by flexible body .welding_robot.trunk_flex was not found. Either the file is not in the proper location or the location of the file is not specified in the aview.pth file. First, examine your aview.pth file to see that it has an entry for .mnf files. Next, make sure that the file exists at the path specified in the aview.pth file打开其他文件时又可能出现仿真跟理想的不对,或者运行仿真第一次的时候出现如图1所示的信息,再运行就出现如图2所示的第二个对话框,单击确定就关闭了。另外在启动adams时弹出的框,里面的信息如图片3所示,这和以前好像不一样 。请高手们帮我解决一下,拜托了! |
