- 2009-4-13
40×40的连续墙基坑,连续墙深度20m,基坑开挖10m,连续墙采用衬砌,加在坑外土体表面;在坑内土体外表面加了接触面。可计算结果为什么如此呢??麻烦各位抽空帮忙分析一下。。谢谢!!!
关键程序如下:
; --- 创建连续墙 ---
group wall range x _x1 _x2 y 0 _y2 z _z1 _z4
group wall range x 0 _x1 y _y1 _y2 z _z1 _z4
range name diaphragm1 x=(19.9,20.1) y=(-0.1,20.1) z=(19.9,40.1)
range name diaphragm2 x=(-0.1,20.1) y=(19.9,20.1) z=(19.9,40.1)
range name diaphragm diaphragm1 any diaphragm2 any
sel liner id=100 crossdiag group wall range diaphragm
sel liner prop iso=(24e9,0.2) thick=0.8 density =2.5e3 cs_ncut=1e3 cs_nk=4e8 &
cs_scoh=20e3 cs_scohres=0.0 cs_sfric=0.0 cs_sk=4e8 slide=on &
range diaphragm
sel group diaphragm1 range diaphragm1
sel group diaphragm2 range diaphragm2
sel group diaphragm range diaphragm
sel link attach zd=rigid xd=free yd=free xrdir=free yrdir=free zrdir=free ran sel liner
;-----------------------施加接触面----------------------
group inner range x 0 20 y 0 20 z 20 40
group outer range group inner not
gen separate inner
int 1 face range group inner x=(19.9,20.1)
int 1 face range group inner y=(19.9,20.1)
interface 1 prop kn=4e9 ks=4e9 tens=1e10 coh=15e3 fric=14.0 bslip=on sbratio=20 ;接触面参数
interface 1 maxedge=4
;interface 1 prop kn=4e8 ks=4e8 tens=1e10 sbratio=100
plot set ba wh
pl ske interface red blue attach cyan green
;-----------------------重新定义墙底约束条件----------------------
def redef_wall_end_link
node_pnt = nd_head
link_id=10000
loop while node_pnt # null
node_id = nd_id(node_pnt)
xx = nd_pos(node_pnt,2,1)
yy = nd_pos(node_pnt,2,2)
zz = nd_pos(node_pnt,2,3)
link_pnt = nd_link(node_pnt)
dist_x = sqrt((xx-20.0)^2+(zz-20.0)^2)
dist_y = sqrt((yy-20.0)^2+(zz-20.0)^2)
dist_tol = 1e-3
if dist_x < dist_tol then
if link_pnt # null then
temp1 = lk_delete(link_pnt)\
link_id = link_id+1
command
sel set link node_tol = dist_tol
sel link id=link_id node_id target zone
sel link attach xdir=rigid ydir=rigid zdir=rigid xrdir=free yrdir=free zrdir=free range id=link_id
endcommand
endif
endif
if dist_y < dist_tol then
temp2 = lk_delete(link_pnt)
link_id = link_id+1
command
endcommand
endif
endif
node_pnt = nd_next(node_pnt)
endloop
end
redef_wall_end_link
附上一些图:
z方向位移图
接触面法向应力
衬砌法向应力 |
