查看: 79|回复: 0
[二次开发] UF_PARAM_set_int_value的用法
发表于 2009-6-5 17:31:47 | 显示全部楼层 |阅读模式 来自 山西太原
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <uf.h>
#include <uf_ui.h>
#include <uf_disp.h>
#include <uf_object_types.h>
#include <uf_obj.h>
#include <uf_modl.h>
#include <uf_curve.h>
#include <uf_assem.h>
#include <uf_ui_ont.h>
#include <uf_ui_param.h>
#include <uf_oper.h>
#include <uf_cam.h>
#include <uf_cam_errors.h>
#include <uf_param.h>
#include <uf_param_indices.h>
#define UF_CALL(X) (report_error( __FILE__, __LINE__, #X, (X)))
static int report_error( char *file, int line, char *call, int irc)
    if (irc)
        char err[133],
             msg[133];
        sprintf(msg, "*** ERROR code %d at line %d in %s:\n+++ ",
            irc, line, file);
        UF_get_fail_message(irc, err);
    /*  NOTE:  UF_print_syslog is new in V18 */
        UF_print_syslog(msg, FALSE);
        UF_print_syslog(err, FALSE);
        UF_print_syslog("\n", FALSE);
        UF_print_syslog(call, FALSE);
        UF_print_syslog(";\n", FALSE);
        if (!UF_UI_open_listing_window())
            UF_UI_write_listing_window(msg);
            UF_UI_write_listing_window(err);
            UF_UI_write_listing_window("\n");
            UF_UI_write_listing_window(call);
            UF_UI_write_listing_window(";\n");
    return(irc);
#define WRITE_S(X) (write_string_to_listing_window(X))
void write_string_to_listing_window( char *string)
    char
        msg[MAX_LINE_SIZE+1];
    UF_CALL(UF_UI_open_listing_window());
    sprintf(msg, "%s\n", string);
    UF_CALL(UF_UI_write_listing_window(msg));
static logical specify_point(char *prompt, double loc[3])
    int
        ia2[2] = { 0,0 },
        ip3 = 0,
        irc;
    irc = uc1616(prompt, ia2, ip3, loc);
    if (irc == 5) return TRUE;
    else return FALSE;
static void do_it(void)
    tag_t        *objects;
        tag_t        point;
    int       i,
              entity_count,
              object_count, err_code, type, subtype,response,
                  TRIM_POINT1_TOG_AUTOMATIC = 0,
                  TRIM_POINT1_TOG_VECTOR = 1,
                  TRIM_POINT1_TOG_ANGLE = 2,
                  togle_off = 0,
                  togle_on = 1;
        double ang_val_radians = 1.57; // 90 degress
        double pos[3];
    char        msg[MAX_LINE_SIZE+1];
        char errorstrg[133];
logical  is_initialized;
logical is_generated;
if (UF_CALL(UF_CAM_is_session_initialized(&is_initialized)) || (is_initialized == FALSE))return;
     while (specify_point("Indicate point location", pos))
        UF_CALL(UF_CURVE_create_point(pos, &point));
        /* Get the highlighted/selected objects from Navigation Tool. */
        UF_UI_ONT_ask_selected_nodes( &object_count, &objects );
        if (object_count > 0)
          UF_CALL( UF_OBJ_ask_type_and_subtype (objects[0],&type,&subtype));
          sprintf(msg,"type is %d subtype is %d",type,subtype);
          WRITE_S(msg);
          if (type == UF_machining_operation_type && subtype == UF_mach_turn_rough_subtype )
                        UF_CALL(UF_PARAM_set_int_value(objects[0],UF_PARAM_TURN_TRIM_POINT1_TOG,togle_on));
                        UF_CALL(UF_PARAM_set_tag_value(objects[0],UF_PARAM_TURN_TRIM_POINT1_TAG,point));
                        UF_CALL(UF_PARAM_set_int_value(objects[0],UF_PARAM_TURN_TRIM_POINT1_ANGLE_TOG,TRIM_POINT1_TOG_ANGLE));
                        UF_CALL(UF_PARAM_set_double_value(objects[0],UF_PARAM_TURN_TRIM_POINT1_ANGLE_VAL,ang_val_radians));
                        UF_CALL(UF_PARAM_generate(objects[0],&is_generated));
           else
             sprintf(msg,"object type is not UF_machining_operation_type and subtype is not UF_mach_turn_rough_subtype");
                 WRITE_S(msg);
           UF_free(objects);
        else
                UF_CALL(UF_UI_open_listing_window( ));
                sprintf(msg,"objects selected in ONT is not equal to 1");
    return;
extern DllExport void ufusr( char *parm, int *returnCode, int rlen )
    /* Initialize the API environment */
    if( UF_CALL(UF_initialize()) )
        /* Failed to initialize */
        return;
    do_it();
    /* Terminate the API environment */
    UF_CALL(UF_terminate());
extern int ufusr_ask_unload( void )
    return( UF_UNLOAD_IMMEDIATELY );
GMT+8, 2024-11-1 15:20 , Processed in 0.033093 second(s), 12 queries , Gzip On, MemCache On.
