HISTORY var
causes a history of the FISH variable or function to be taken during stepping. If var is a function, then it will be evaluated every time histories are stored (controlled by HISTORY nstep command); If var is a FISH variable, then its current value will be taken. Hence, caution should be exercised when using variables (rather than functions) for histories. The history may be plotted in the usual way.
HISTORY var
