- 2007-1-8
做了一个简单的UMAT子程序,在计算时出现以下错误,首先,UMAT子程序编译没有错误。去msg,dat文件里也没找到错误指示,帮助里也没查到,请问大侠们,这个错误一般是由哪些因素引起的?或者帮助里有错误的指导吗?附上错误文件。
The executable D:\ABAQUS\6.7-1\exec\standard.exe aborted with system error code 144. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code. |
