查看: 46|回复: 1
版主 高手请进 谢谢先! 热分析时碰到的问题
发表于 2009-9-23 10:23:54 | 显示全部楼层 |阅读模式 来自 大连理工大学
1.收敛问题
   Solution not converged at time 4 (load step 2 substep 1).
  Run terminated.          做的热分析(铸造方面的) 命令流如下:
antype,trans
timint,off
time,1
deltim,1
aplot
asel,s,,,1
nsla,s,1
d,all,temp,1500
allsel
nsla,s,,,2
nsla,s,1
d,all,temp,25
allsel
lplot,all
lsel,s,,,5,7
nsll,s,1
sf,all,conv,10000,25
allsel
solve
timint,on
time,200
autots,-1
deltim,3,3,10,1
kbc,0
ddele,all,temp
outres,all,all
solve
finish
问题2:
*** WARNING ***
There are no active degrees of freedom.
*** WARNING ***
Material property DENS of material 2 of element 15 is evaluated at a
temperature of 0, which is below the supplied temperature range.
Temperature range checking terminates.
 楼主| 发表于 2009-9-23 14:52:16 | 显示全部楼层 来自 大连理工大学
自己顶下先 急盼大侠点拨。。。。
GMT+8, 2024-9-20 23:23 , Processed in 0.052359 second(s), 13 queries , Gzip On, MemCache On.
