这两天要用SYSNOISE分析,可以一直装不了,急死了,现在主要问题还是EXCEED7.1装不上,我的机子是VISTA的系统,点了EXCEED 7.1的安装之后装了一段时间后出现:
The wizard was interrupted before Humming Bird Exceed could be completely installed.
Your system has not been modified. To complete installation at another time,please run setup again.
后来换了一台XP的也是这样,在网上重新下了一个还是这样的提示。有没有人遇到这种情况,能不能告诉我怎么解决的?
