- 10
- 2007-10-5
#include <stdio.h>
#include <string.h>
#include <uf.h>
#include <uf_ui.h>
#include <uf_object_types.h>
#define UF_CALL(X) (report_error( __FILE__, __LINE__, #X, (X)))
static int report_error( char *file, int line, char *call, int irc)
if (irc)
char err[133],
msg[133];
sprintf(msg, "*** ERROR code %d at line %d in %s:\n+++ ",
irc, line, file);
UF_get_fail_message(irc, err);
/* NOTE: UF_print_syslog is new in V18 */
UF_print_syslog(msg, FALSE);
UF_print_syslog(err, FALSE);
UF_print_syslog("\n", FALSE);
UF_print_syslog(call, FALSE);
UF_print_syslog(";\n", FALSE);
if (!UF_UI_open_listing_window())
UF_UI_write_listing_window(msg);
UF_UI_write_listing_window(err);
UF_UI_write_listing_window("\n");
UF_UI_write_listing_window(call);
UF_UI_write_listing_window(";\n");
return(irc);
#define WRITE_D(X) (write_integer_to_listing_window(#X, X))
static void write_integer_to_listing_window(char *title, int n)
char
msg[MAX_LINE_SIZE+1];
UF_CALL(UF_UI_open_listing_window());
sprintf(msg, "%s = %d\n", title, n);
UF_CALL(UF_UI_write_listing_window(msg));
static void do_it(void)
int
response = 0;
char
*messages[3] = { "Message One", "Message Two", "Message Three" };
UF_UI_message_buttons_t
buttons;
buttons.button1 = TRUE; /* OK button */
buttons.button2 = TRUE; /* BACK button */
buttons.button3 = TRUE; /* CANCEL button */
buttons.label1 = "MY_OK";
buttons.label2 = "MY_BACK";
buttons.label3 = NULL; /* will use the default value */
buttons.response1 = 2;
buttons.response2 = 4;
buttons.response3 = 6;
UF_CALL( UF_UI_message_dialog( "My Dialog Title",
UF_UI_MESSAGE_INFORMATION,
messages, 3, FALSE,
&buttons, &response ));
WRITE_D( response );
/*ARGSUSED*/
void ufusr(char *param, int *retcode, int paramLen)
if (UF_CALL(UF_initialize())) return;
do_it();
UF_terminate();
int ufusr_ask_unload(void)
return (UF_UNLOAD_IMMEDIATELY);
