查看: 372|回复: 2
[MADYMO] 请教问题:XML parse error,怎么解决
发表于 2009-10-20 19:23:29 | 显示全部楼层 |阅读模式 来自 北京
Running D:/software/Madymo_621\win32p\bin\bsaf.exe "E:/madymo/template20091020.xml" "template20091020.saf"
Opening file 'E:/madymo/template20091020.xml'
Opening file 'D:/software/Madymo_621/share/etc/mtd_3d.dtd'
Opening file 'D:/software/Madymo_621/share/etc/mtd_3d_type.txt'
Opening file 'D:/software/Madymo_621/share/etc/mtd_3d_range.txt'
Opening file 'D:/software/Madymo_621\share\etc\typedefs.xml'
Opening file 'D:/software/Madymo_621\share\etc\mtd_3d.dtd'
XML parse error:
file=E:/madymo/template20091020.xml line=30 column=21
This type of attribute cannot have an empty value
**   ABORT ** ID=(INPI41/3D/CMDL3D)
Failed to parse the XML input file. Use the MADYMO Reference manual to
assist with correction of the errors in the input deck.
MADYMO TERMINATED ABNORMALLY, because of ERRORS.
Stopped Tue Oct 20 19:18:55 2009
发表于 2009-10-20 21:43:54 | 显示全部楼层 来自 上海
错误信息已经说得很清楚了,用UltraEdit打开 template20091020.xml文件,检查第30行(line=30)、21列 (column=21),此attribute不能为空 (empty)
 楼主| 发表于 2009-10-20 22:03:01 | 显示全部楼层 来自 北京
多谢!问题已解决,以后还请多指教
GMT+8, 2024-11-1 23:27 , Processed in 0.034139 second(s), 12 queries , Gzip On, MemCache On.
