- 16
- 2009-3-4
发表于 2009-10-27 11:40:16
来自 重庆
LZ 神秘消失?
如果你是写论文,看到别的手册的数据,那么,请用 GetData软件
这个软件,可以获取图片上的点。当然,你得先 用扫描仪或照相机,把手册上的图片弄到电脑
如果写论文时想和比人的数据进行对比,但只有图片--坐标图,没有别人的原始试验数据,那,getdata软件不错!
。GetData Graph Digitizer is a program for digitizing graphs and plots. It is often necessary to obtain original (x,y) data from graphs, e.g. from scanned scientific plots, when data values are not available. GetData Graph Digitizer allows to easily get the numbers in such cases. Digitizing is a four step process:
1. open a graph,
2. set the scale (coordinate system),
3. digitize (automatically or manually), and
4. copy data to the clipboard, or
export to TXT, XLS, XML, DXF or EPS file. |
