- 2008-3-17
[命令/FISH] 锚杆支护锚杆, 支护锚杆, 支护
高手 您好 您编写的是全锚索支护的情况 一根锚索不需分段 现在我正在做一个有托盘的锚索 可是在运行过程中老是出现soure node not near enough to an exsiting non-null zone 现在将程序传上来望您指点 谢谢
new
gen zone brick size 10 10 10 &
p0 0 0 0 p1 10 0 0 p3 0 0 10
model mohr
prop bulk 1e8 shear 0.3e8 fric 35 coh 1e10 ten 1e10
set grav 0 0 -9.81
ini dens 1000
fix x range x 0
fix x range x 10
fix y range y 0
fix y range y 10
fix z range z 0
hist unbal
set hist_rep 10
solve
save 初始平衡.sav
ini xdisp 0 ydisp 0 zdisp 0
ini xvel 0 yvel 0 zvel 0
model null range x 0 2 y 0 2 z 0 2
solve
save 1次开挖.sav
restore 初始平衡.sav
def place_cables
loop m(1,2)
caseof m
case 1
x_d1=0.5
x_d2=0.5
x_d3=0.5
y_d1=0.5
y_d2=0.5
y_d3=0.5
z_d1=1.5
z_d2=2.0
z_d3=3.5
a=1
b=2
c=3
d=6
id_11=1
id_111=1
case 2
x_d1=0.5
x_d2=0.5
x_d3=0.5
y_d1=1.5
y_d2=1.5
y_d3=1.5
z_d1=1.5
z_d2=2.0
z_d3=3.5
a=15
b=16
c=17
d=20
id_11=3
id_111=15
endcase
loop n(1,2)
x_d1=x_d1+1
x_d2=x_d2+1
x_d3=x_d3+1
y_d1=y_d1
y_d2=y_d2
y_d3=y_d3
z_d1=z_d1
z_d2=z_d2
z_d3=z_d3
a=a+(n-1)*7
b=b+(n-1)*7
c=c+(n-1)*7
d=d+(n-1)*7
id_11=id_11+1
id_111=id_111+(n-1)*7
command
sel cable id=id_11 beg x_d1 y_d1 z_d1 end x_d2 y_d2 z_d2 nseg 2
sel cable id=id_11 beg x_d2 y_d2 z_d2 end x_d3 y_d3 z_d3 nseg 4
sel cable id=id_11 prop emod 2e10 ytension 3.1e5 xcarea 0.0004906 &
gr_coh 1 gr_k 1 gr_per 0.0785 range cid a,b
sel cable id= id_11 prop emod 2e10 ytension 3.1e5 xcarea 0.0004906 &
gr_coh 10e5 gr_k 2e7 gr_per 0.0785 range cid c,d
sel delete link range id id_111
sel link id=id_111 id_111 target zone
sel link attach xdir=rigid ydir=rigid zdir=rigid xrdir=rigid yrdir=rigid zrdir=rigid range id id_111
sel cable id=id_11 pretension 60e3 range cid a,d
endcommand
end_loop
end_loop
end
place_cables |
