- 2009-11-9
由前桥(fro_axle)模板+板簧(leaf)模板+testrig组装成fro_sus_assembly,设置好仿真参数后进行static load,最终出来以下信息:
---- ERROR ----
***** ADAMS MEMORY OVERFLOW *****
A larger LD array is required.
The error occurred in subroutine "DPVFC" while allocating "CHAR" space
for the "second expression".
Space Available: 0 Space Requested: 3
ADAMS/Solver requires more program memory to run this model.
Be aware that the above figures for Space available and Space
requested only reflect the current requirements. Additional space
may be required later in the solution process.
Several off-the-shelf memory configurations are available and
custom configurations may be created. The available memory models
and the corresponding array sizes are:
NAME LCEXPR LDSIZ
STANDARD 100 2,000
LARGE 200 2,000
EX-LARGE 300 2,000
HUGE 300 5,000
where the columns correspond to:
LCEXPR : Maximum number of lines in a Function
LDSIZ : Maximum total number of lines in all Functions
To use an alternative setting, you have to start the ADAMS 'Settings'
program. It can be found using the Start menu:
Start -> Programs -> MSC.Software -> MSC.ADAMS -> ADAMS-Settings
Alternatively, you can start 'adams_settings.exe' in the 'utils\win32'
folder of your ADAMS installation directory.
Terminating ADAMS/Car usersubs...
ID = 1
ADAMS/Solver execution terminated by subprogram LSPACE
CPU time used = 141.53 seconds
ERROR: An lookup operation was still in progress when AMD was shut down.
ERROR: Error type: ae_lookup_unfinished
ERROR: Parent name: .fro_sus_test_static_load
ERROR: Parent type: ao_model
ERROR: Search type: ao_vforce
Analysis failed!
Please check the error messages to determine the cause.
实在弄不明白,烦请高手指点一下。 |
